simmonsj17
Hello,
I seek advice / recommendations for my build. Already have a frame and battery cells. I weigh 198lbs, want to achieve speed of around 30mph maybe more just don't want to cook anything, not a commuter just to play around on.
Frame: ebay EEB frame
Battery: 66v nominal, 250a cont discharge, 600a pulse
Cells: A123 Lifepo4
Max cont discharge 50a
Max pulse discharge(10sec) 120a
Config: 5p20s
Bms: ????? Ant bms??
Charging: ?????
The data sheet that came with the cells says nominal voltage is 3.3 and recommended charge method 2.5A to 3.6v so should i look for a 72v 12.5a charger???
Motor: ???? Qs205 with ferrofluid and heat sinks?
Controller: ????
Tire and wheel: ??????
Should I go with moped wheels or bike????
Cells: A123 Lifepo4
Config: 5p20s
Charging: ?????
Controller: ????
