How do you think solid state batteries will change how we use hardware?
ebike4healthandfitness   10 kW
Re: How do you think solid state batteries will change how we use hardware?
Post by ebike4healthandfitness » Jan 20 2022 7:35pm
Some more info on NIO's semi solid state batteries that are scheduled to be in production cars later this year:
https://www.autoevolution.com/news/nio- ... 75124.html
According to what Li said at the time, this semi-SSB would comprise “in-situ solidified solid-liquid electrolyte, inorganic pre-lithiated carbon-silicon anode, and nano-scale ultra-high nickel cathode.”
Of interest is the investment by Huawei and Xiaomi which means we could see the tech in mobile computing devices and micro-mobility.
Post by ebike4healthandfitness » Jan 21 2022 12:07am
Chalo   100 GW
Post by Chalo » Jan 21 2022 12:15am
ebike4healthandfitness wrote:
Jan 21 2022 12:07am
1.15 kwh per liter (oh yeah!!)
Claimed.
We know about battery claims.
Post by ebike4healthandfitness » Jan 21 2022 12:35am
Here are some you can buy:
https://www.foxtechfpv.com/foxtech-diam ... ttery.html
There is a man who tested them in this thread named RichardG:
https://community.openppg.com/t/new-bat ... ty/2274/43
Foxtech:
The ultimate, money-no-object highest power density per weight is the Foxtech Diamond. A similar pack configuration to the Bonkas. I have posted my capacity investigation on these in this thread above.
These are what Foxtech call semi-solid lithium. They have impressive energy density specifications, which my testing has confirmed.
4 x Foxtech Diamond gives 7% more energy for 15% less weight than 4 x Bonkas.
But costs 28% more.
The Foxtechs are very difficult to get hold of ( but I now have four!)
They need re-wiring with thicker cable to work with OpenPPG.
The Foxtech’s longevity is yet to be tested.
They are currently only available in a 6S configuration.
Post by ebike4healthandfitness » Jan 21 2022 2:13am
Chalo wrote:
Jan 21 2022 12:15am
Jan 21 2022 12:07am
Claimed.
Actually they didn't claim 1.15 kWh per liter. I thought I had derived that from the energy capacity vs. volume, but I made. a mistake and 1.15 liters is the volume.
570 watt hours/1.15 liters gives .496 kWh per liter.
Post by ebike4healthandfitness » Jan 21 2022 2:24am
If anyone is wondering the semi-solid state batteries sold by Foxtech have specs which match up exactly with those of solidstatelion.com (the company which is making the semi solid state batteries for NIO).
An example would be to compare this one:
http://www.solidstatelion.com/en/product_page/294.html
....to the 7s 22000mAh in the Foxtech chart below:
(Both have exactly the same dimensions and exactly the same weight. It seems obvious that Foxtech is buying these from solidstatelion.com and rebranding)
speedmd   1 GW
1 GW
Post by speedmd » Jan 21 2022 11:12am
Interesting times watching the news releases on EV battery tech. Reminds me of a food fight. Tremendous amounts of investment and a turf fight to boot. Interested in seeing how the 46-80 format proves out and the LFP format that develops over the near future. Looking at the numbers, the lowest cost, and most reliable will most likely own it as most of the current designs will not find a market unless they show much better performance characteristics that justify the added expense.
LewTwo   1 MW
Post by LewTwo » Jan 21 2022 6:23pm
speedmd wrote:
Jan 21 2022 11:12am
If past PR announcements are any indication then 90% will prove to be "all hat and no cattle".
The more I learn the more obvious the immensity of my ignorance becomes.
Weight Wennie E-Bike https://endless-sphere.com/forums/viewt ... 3#p1173723
Shaft Drive Grocery Getter https://endless-sphere.com/forums/viewt ... =6&t=90718
...and thanks to Justin!
Post by ebike4healthandfitness » Jan 21 2022 9:56pm
speedmd wrote:
Jan 21 2022 11:12am
Apparently solid state battery design works with both LFP and high nickel cathode designs:
https://www.quantumscape.com/resources/ ... -platform/
Post by ebike4healthandfitness » Jan 21 2022 10:12pm
Here is something I thought was very interesting while I was researching the NIO semi solid state batteries:
https://insideevs.com/news/561903/norwa ... tery-swap/
Post by ebike4healthandfitness » Jan 22 2022 1:19am
Jan 21 2022 2:13am
Chalo wrote:
Jan 21 2022 12:15am
Jan 21 2022 12:07am
Claimed.
Comparison:
A Samsung 25R cell has a volumetric density of 527 wh per liter. However, once assembled into a EM3ev rectangular battery pack volumetric density drops to around 235 Wh per liter.
https://em3ev.com/shop/50v-14s7p-rectan ... tery-pack/
So the foxtech semi-solid state batteries at 496 Wh per liter have more than twice the volume density as a well designed 18650 cell battery pack using the Samsung 25R. (Furthermore, Foxtech lists the semi state battery packs up to 14S with 30Ah and these larger packs still have roughly the same Wh per volume as the smaller packs. e.g. 14S30Ah has 498 Wh per liter.)
