Eastwood
- Joined
- Jan 13, 2021
- Messages
- 1,470
Edit: problem solved, read below.
So I’m getting this error code 02H while applying full throttle and only when the rear wheel strikes some tree roots or something like that causes up spring. This code never happens if I ride on the street. It only happens when I’m riding off road and I’m giving full throttle and the back wheel is bouncing over roots or a ditch or something and it cuts out instantly. I had the same exact set up with my Mxus 3k 5T And it never cut out never. I’m not sure why the QS205 motor is doing this and it Has to be something within the controller. I have considered maybe the wires are pinched near the axle or something but my guess it’s something with one of the settings in the controller and I can’t figure it out. I mean I’m still able to ride like normal I just have to be careful when I see big roots because I know it will cut the motor out if I get up spring while applying full power. Sidenote this does not happen when I lower my power setting down to say even 60% it doesn’t cut out so it only happens at full power during the rear wheel/motor striking roots or a ditch…
Maybe you guys have had similar experiences or could shed some insight. I’m planning to hit some ATV trails today and would love to not have to worry about this dang 02H code
Thanks Guys!
Thanks Guys!
