E-HP said:
ebike4healthandfitness said:
So (for example) if the load on a 60 psi tire is 240 pounds the size of the contact patch will be 4 square inches. Likewise if the load on a 40 psi tire is 240 pounds the size of the contact patch will be 6 square inches.
Just to understand the scenario, is the idea that using the
same tire, but filled to 40psi vs 60psi, running the lower pressure will have less rolling resistance?
I hope that's not what he's saying, but if so, it would be characteristically mistaken.
Working rubber uses energy. Work it more, or have more rubber being worked, and you spend more energy. That's why moto tires are slow and draggy even when they're wide enough and lightly loaded enough to not exhibit much deflection. There's just a lot of rubber undergoing hysteresis.
If your riding surface is so bad that you lose a lot of energy to shocks that are transferred to your body or payload, then the energy saved by shock absorption from soft tires might exceed the energy lost to rolling resistance from soft tires. That's not how most of us ride most of the time. It's more likely to be a factor when folks use tiny thin high pressure tires for speed, and lose more speed to vibrations than they gain from low RR.
