Video of Pedals that switch to foot pegs
Quinc   100 W
Post by Quinc » Jan 22 2022 6:59pm
Got these for my Sur-ron but they will work on any bike. Great option if you want to ride through public areas before hitting the trails.
calab   100 kW
Re: Video of Pedals that switch to foot pegs
Post by calab » Jan 22 2022 7:23pm
Very cool to make your electric bike have pedals but it should really be electric disconnect so you dont have to stop and manually change it.
Quinc wrote:
Jan 22 2022 6:59pm
https://youtu.be/6tPVFBzcnSI
LewTwo   1 MW
Post by LewTwo » Jan 23 2022 12:09am
Interesting ... Until I saw the price :bolt:
The more I learn the more obvious the immensity of my ignorance becomes.
Weight Wennie E-Bike https://endless-sphere.com/forums/viewt ... 3#p1173723
Shaft Drive Grocery Getter https://endless-sphere.com/forums/viewt ... =6&t=90718
...and thanks to Justin!
calab   100 kW
Post by calab » Jan 23 2022 12:35am
https://hightailebikes.com/products/pegale
$359 is crazy for a square tapered fit.
Quinc   100 W
Post by Quinc » Jan 23 2022 10:00am
calab wrote:
Jan 23 2022 12:35am
American made and the time it took to design and test etc. I thought it was a great deal considering the cost and time to make my own.
Chalo   100 GW
Post by Chalo » Jan 23 2022 11:05am
calab wrote:
Jan 23 2022 12:35am
Nothing wrong with using the proven choice that will still be supportable in a few years after the new hotness standards have been abandoned in favor of newer hotness. I don't love square taper, but it isn't going anywhere.
Octalink V1 anyone? PowerSpline?
Eastwood   10 kW
Post by Eastwood » Jan 24 2022 3:56am
But these look like they continue to swivel.
:bolt: Suzuki Rmz 250 EV Restomod :bolt:
viewtopic.php?f=12&t=116038&p=1716022#top
:bolt: Enduro Frame build :bolt:
viewtopic.php?f=6&t=113133
LewTwo   1 MW
Post by LewTwo » Jan 24 2022 11:16am
Personally I would rather see something that locks the BB in a position and flips one of the cranks 180 degrees. Something forward to rest my feet on while still legally being equipped with something that could be called a functional pedal system.
However I do not stand on the crank. I can understand the desire to keep the CG more centered to the BB in that case.
Quinc   100 W
Post by Quinc » Jan 24 2022 9:14pm
Eastwood wrote:
Jan 24 2022 3:56am
I thought that was going to be an issue, but after riding through a field of large rocks and boulders etc It wasn't an issue. Looking more into locking them into place and it wont work because the bike would not be able to roll backward. Unless there is a freewheel sprocket that would allow both forward and backward spinning?
amberwolf   100 GW
Post by amberwolf » Jan 24 2022 10:23pm
Quinc wrote:
Jan 24 2022 9:14pm
How would you pedal?
Taking the chain off the rear sprocket would be the only viable option without custom building some kind of user-switchable internal clutch into your BB or your rear wheel.
Beginning of a New Life
Give a listen to my music!
(More here, including experimental)
Quinc   100 W
Post by Quinc » Jan 25 2022 11:03am
amberwolf wrote:
Jan 24 2022 10:23pm
Quinc wrote:
Jan 24 2022 9:14pm
I figure stranger things exist! Riding it some more the pegs moving hasn't been an issue at all.
I think its a matter of time now until the little freewheel on the crank lets go from the high speeds.
LewTwo   1 MW
Post by LewTwo » Jan 26 2022 1:42am
amberwolf wrote:
Jan 24 2022 10:23pm
Quinc wrote:
Jan 24 2022 9:14pm
That might be a tad inconvenient for a mid drive :wink:
Do the cranks on a Bafang BBS02 freewheel?
Edit: One direction only I am thinking :(
amberwolf   100 GW
Post by amberwolf » Jan 26 2022 6:29pm
LewTwo wrote:
Jan 26 2022 1:42am
amberwolf wrote:
Jan 24 2022 10:23pm
Quinc wrote:
Jan 24 2022 9:14pm
Yes, but it is the only way to do what he wants (be able to lock the pedals and not have them affect the wheel) without redesigning and rebuilding parts of the drivetrain.
For a middrive, it would not be able to be a crank-centric type if the pedals must be able to be locked into position, without redesigning the middrive. It would have to input power into the drivetrain somewhere else, past the pedals. The "simplest" way is a left side drive, totally separate from the pedals; short of that simplest is to have the pedals drive a chain that drives an input sprocket on the motor drivetrain and then the motor drives the wheel via separate chain. A simple freewheel at the pedal chain input to the motor drivetrain would prevent backdriving the cranks and thus allow them to be locked without affecting the motor. If they must be lockable during backwards movement, a clutch must be used instead of a freewheel, that can completely disengage the pedal chain from the rest of the system, or the chain must be removed when the pedals are locked.
Same is true of a left side drive motor system; pedals still need clutch or take off chain.
A hubmotor you just take the chain off (or build a clutch system).
That was why I asked "How would you pedal?" to his suggestion; if it freewheels both ways then there is no way to drive anything from it (or by it).
Quinc   100 W
Post by Quinc » Jan 29 2022 1:45pm
My bmx bike can roll forward and backward without the pedals moving. Going to need to take a closer look and see what it is using.
Chalo   100 GW
Post by Chalo » Jan 29 2022 1:53pm
Quinc wrote:
Jan 29 2022 1:45pm
That's called a freecoaster hub. In days of yore they were made by modifying regular coaster brake hubs, but for a long time now they've been manufactured for the purpose. Forward drive input at the sprocket engages the clutch. When there's no forward drive, it disengages and allows the wheel to rotate freely in either direction.
calab   100 kW
Post by calab » Jan 29 2022 2:03pm
Just saw an autobike for sale for uber cheap, I had to do a google search, but yeah freewheel cranks were a thing of yores past. Did not shimano make one in dinosaurs age? https://bikeretrogrouch.blogspot.com/20 ... ranks.html
Quinc   100 W
Post by Quinc » Feb 08 2022 12:01pm
calab wrote:
Jan 29 2022 2:03pm
Learn something new everyday! So far the pegals are doing well not locked into place. So going to give up on the idea of redesigning the freewheel. :pancake:
Quinc   100 W
Post by Quinc » Feb 22 2022 12:26pm
Latest update is the screw is coming loose even with blue loctite. Going to try Red loctite next.
