999zip999
100 TW
:wink: So getting rid of my old turning stand out of a bed frame this one is going to be a little more custom.[attachment=2]IMG_20221218_162927285.jpg[/attachment
So the first two are my original bed frame stand where it was already riveted and I just used it and made one weld at the top then cut it open for 10 mm axle.
The last two are the new frame that I had to cut up differently one where I put a little 1 inch filler and the other for a 7-in filler which would make the bottom pivot 22 in I'm going for 15 in high.
I'm going to make it for front motors I believe are 110 mm and all the way to 170 mm for the 50 mm magnets. I guess that should cover it ?
Anybody have anything to add before I start welding and cutting this thing up I might want to make it thicker at the top with a plate up there that would be wider and enough room to put a big axle nut on.]
