Chainless drive
The concept is valuable for those who don't intend to pedal because it makes it easy to add pedals without worrying about a chainline. In Iowa one of the requirements for electric bicycles is "operable pedals".
Drunkskunk said:
Cute. From an engineering perspective, that is such a bad idea. The efficiency loss over a chain drive makes me die a little inside.
Amen
Also it is NOT 'the first chainless drive e-bike'.
Back around 2006 I had an Incline shaft drive bike with electric front hub.
Wish I still had it as Sussex no longer seems to be build shaft drives.
There are also a few Gates Belt drive e-bikes out there as well.
Edit: I left out the PROTANIUM SHAFT DRIVE
http://ecruiserbikes.com/our-bikes/shaft-drive/
Trouble loading page correctly so I can't see it but I found a pic in google cache.
Seems that they are using "drive by wire"? A hub in the rear and I am guessing a optical sensor and pas senors or something in the crank to tell the motor to turn?
Hm that crank housing seems oddly large, one would think it contains a gearbox judging by the size. Or it could be a tiny shaft drive from the crank housing that turns when pedals turning and running inside the swing arm, impossible to see on the one pic I found. But that would explain the large size of crank housing.
Man if they are using a hidden shaft drive and did not route the motor wires inside the swing arm they must have something dislocated or partly damaged in the head.
Did someone figure out how this work?
Hillhater said:
Nothing new here......Its just the old crank driving a generator, which then powers the hub motor.i
Efficiency losses at each stage !
Well, there's a battery plumbed in the circuit. The pedaling seems to control speed and there's several selectable power limits/levels.
I'd think pedaling this with a flat battery to be something like pedaling a moped, which is what this is, basically.
Might be a better system for this conveyance that you'd never really pedal:
http://www.gizmag.com/lithium-cycles-super-73-e-bike/43659/
Sussex is owned by a Chinese manufacturer and still available.
http://www.chainlessbike.com.cn/
Basically looks like they have taken the concept from the Mando Footloose and made it into a kit.
http://www.mandofootloose.com/en/?nation=us
Not really a kit as much as a system, since it requires a customized and prioprietary frame design...
+1.. there goes 20-40% of your pedal input.
Hehe no reason to go to the gym for spinning classes anymore. Get yourself a bike 2.0 and you are really getting a workout on the way to work.
The Taiwan SUSSEX site is unresponsive. They also do not respond to emails.
H'mmmm ... This is from the English version of their Chinese site:
http://www.chainlessbike.com.cn/index_en.html
"From June 1, 2015 start, Goldmann (Taicang) Machinery Co., Ltd. to take over the world welcomed the company's all business. We continue to provide you as before and high quality products and services."
There does not appear to be anyone selling bicycles with their shaft drive.
Dynamic Bicycles US no longer advertises shaft drive bicycles.
Dynamic Bicycles UK web site still shows products for sales but the latest update to their site is dated: September 2014
There is still one Sonoma shaft drive bicycle listed on Amazon (Prime) but my guess it is the last of the stock.
No apparent activity there since 2014 either.
Edit:
One listing for a 'NEW' Sonnona on ebay as well (Same model as Amazon but $100 more).
Found another listing in France: http://www.arcadecycles.eu/Urban-bicycle/velo-cygnus-1903-nex-3.html (caution: very slow responce time)
For all practical purposes I would say that they packed up their tent and went home.
EDIT 30 September 2016:
Well I have to eat my words ...
Dynacraft BSC, Inc. is marketing a couple of Sussex shaft drive bikes via Amazon .... and I purchased one.
https://endless-sphere.com/forums/viewtopic.php?f=3&t=83817&p=1227440#p1227440
Sometime surprising and amazing what one can find on Alibaba ...
Chainless shaft drive Ebike:
http://www.alibaba.com/product-detail/26-aluminum-7-speeds-new-products_802943232.html?spm=a2700.7724838.0.0.d8MQt3
But that's a totally different design in that the pedals are still mechanically linked to the wheel, not driving a generator to feed the battery.
Yes it is but my point was that Bike2's claim
Is subject to question/argument (which I believe originally stated 'the first chainless drive e-bike' ... I do not usually misquote people).
Hillhater said:
...but it is what LewTwo was searching for !....
Sorta of ... it is close to what I was riding in 2006 (mine had 3 Hawker 12V SLA's in the triangle and no suspension fork).
