bentstrider83
I've been riding with my Catrike Expedition with my Bafang 750 equipped for the past month. While I had the motor on my single-speed, Schwinn World Tour, I would routinely do a 15 mile roundtrip and still have a 75% capacity on the C961 display when I got home. However, the rough roads were tearing up my tubes out here so I put it on my Trike and started riding that.
The ride is much more comfortable and the constant speed I get from having the Bafang on the trike is like nothing I've felt before. However, the battery drain for the same round trip leaves me with 50% capacity when I get back to the house.
I'm currently using a 52V/13.5AmpH battery and use level 3-4 PAS as opposed to continuous use of the throttle. I'm suspecting a big part of the drain would be the simple fact that pushing two, 1.5' tires at the front is more work than a single set of road tires in a normal bicycle configuration. Apart from just merely getting a spare battery of the same type, I was also looking at some of those 48v and 52v options with a 20-24 AmpH rating on the Luna Cycles site.(I'm just going with those AmpH ratings using the charts and math on that site.).
Other than the range thing from the battery, this motor has given me nothing but satisfaction for the most part, and that's on both of the bikes/trikes I use them on.
