I've currently got a rear direct drive hub motor on a 26" wheeled mountain bike.
I'm happy with the circa-30mph speed.
But, I'd like to be able to contribute a bit too, without spinning too fast.
Unfortunately 26" wheels with a freewheel rather than cassete means something like 42/14 highest ratio. (Haven't checked.)
I could up the front chain ring a bit; but I'm used to my road bike/hybrid which are are 50/11 on 29" wheels (though skinnier tyres)* and it's not going to come that close - still spinning fast.
(*actually the road is 50/12 I think, with even smaller tyres, so probably a bit lower geared than the hybrid.)
I always liked the idea of a mid-drive, especially for off road - coming from motorcycles/mountain bikes, making the wheels light is often a big factor in improving performance, never mind just having more gears, which seems better. However it seems typically the motor spins the crank pretty fast.
Some direct drives allow a cassette; though I believe these are often a bit wider than normal dimensions.
Or I could go back to finishing off adding a RC outrunner to the front of the hybrid (chain driven with rear BMX wheel) - but I suspect heat would be an issue there as that plan was intended more for 'boost' power than continuous.
Finally; I could go for a geared hub on the front of a hybrid, giving me the normal chain line.
Any recommendations etc?
