I as understood optimal cadence for BBS01 250w is around 70 RPM. Let's say I will maintain cadence around 70-90 RPM in long steep section (e.g. 15% on 0.2mile) - in that moment I need maximal power from my mid drive motor. I do not want to use throttle (illegal in my country) only PAS. My battery has 36v/14ah, 20a continuous current.
So far I changed only following things :
- PAS level 9, limit current : 100%, limit spd. 100%
- limited current increased from 18amp to 20amp (20amp is maximum)
- speed limit is without changes = 15mph (that's legal limit in my country)
Isn't sweet spot for the motor (~ 70 RPM) in steep sections somehow limited by too low speed limit ? Are there any other settings which could help me to get max. power from motor in steep sections ? ...of course I am pedaling actively as hard as possible (chain ring 42t + largest rear wheel 32t). I plan to install temp. probe to be sure I am not killing my motor.
