speedyebikenoob
- Joined
- Feb 6, 2019
- Messages
- 333
I'm strongly considering putting a Cycle Analyst on my bike, but I do have a couple questions and concerns, hopefully those of you who own it can help me out? First concern is pretty minor and it's not really a deal breaker, but my bike already has about 300 miles on it and I was wondering if there was any way to input those into the cycle analyst odometer, so I wouldn't start from zero. My other question, more important to me for obvious reasons, is the torque throttle setting. I've gone through other threads on this forum, but still couldn't really understand it. If my controller is PWM based, how would the cycle analyst be able to turn it into a "torque throttle" if all it's controlling is the throttle input? Even if it makes the throttle ramp up rate steeper, twisting the throttle 70% with the CA would still give me 100 percent torque as it does now? Regardless of how it works, for those of you who have it on your bikes, does it actually work? Also, will it limit performance in any way? I really like the power of my bike right now, my controller is 40 amps, but from what I understand that's a continuous rating and peaks can go well above that? Will using the torque throttle setting eliminate the high amperage peaks that make my bike quick off the line?
