Hello,
I've got a frame with a slot for a seatpost battery. Now the orginal battery is super tiny (30cells max), but there is enough space for a much larger one, provided the aluminum body tube of the battery is long enough. Now I've been searching for ages, contacting chinese aluminium extrusion companies to find one which has the die for that profile in order to get a longer tube - without any sucess so far. Closest thing I found is a 86*88mm tube with super large radius corner, which fits 25% less cells because of the wasted space. Can anyone help me find whichever company made the original tube, or has the correct die ?
Here is a drawing of the cross section of the tube I'm looking for. It's based on the readily availabe 86*88mm tube, whith the required modifications to fit both enough cells and into my frame, like the original battery.
This is what the original battery looks like:
Thank you for your help
