Vikingimike01
- Joined
- Mar 31, 2019
- Messages
- 48
Hey forum!
So, I bought 2x 72v, 30A continous output batteries, 75A max.
I am planning on wiring it in parallel, to increase max amper. It has a BMS.
But, when I told the seller, he said this:
"This battery continuous current is 30A , it dertimes by BMS , it won't change to 60A even you use two batteries .
Our description has clearly clarified that , this battery can fit for 72V 750W-1500W ( Can't be more than 1600W ) ."
Is this true? Can I not wire up 2 in parallel to increase the max amperage for a 5kw ebike hub?
