HT3525 and Lyen controller pinout
zulunation
100 µW
Hello everyone,
I have HT3525 motor from crystalite-europe.com. I want to connect it to Lyen controller.The problem is the pinout.
Lyen controller has the following pinout:
YELLOW - A phase
GREEN - B phase
BLUE - C phase
Motor has pinout:
YELLOW - 1 phase
GREEN - 2 phase
BLUE - 3 phase
Does 1 phase mean A. 2 mean B and 3 mean C?
So i connect
YELLOW to YELLOW
GREEN to GREEN
BLUE to BLUE
Is that correct?
Thanks
color to color might work.
If not, swap the blue and yellow phase wires.
When you first try to spin the motor, just barely tap the throttle and see what happens. If it spins fast, you probably have the right combo. If it stalls, try again.
( also, if it stalls, do not continue to hold the throttle down or else a motor or controller could blow! )
https://endless-sphere.com/forums/viewtopic.php?t=3484#p51067
https://endless-sphere.com/forums/viewtopic.php?f=1&t=32455
https://endless-sphere.com/forums/viewtopic.php?t=6241
Hello again and thanks for reply
I have checked all 36 combinations with ampermeter.
I found that there are 3 combinations for which noise is the lowest, easy start and current at the full throttle is 1.8A.
Now i can't distinguish between these combinations.
I guess they are equivalent but not sure.
