BionicBlitz
1 W
- Joined
- Jun 13, 2018
- Messages
- 53
amberwolf said:Unfortunately, the software for programming most controllers cant' read the actual controller values. So what you see on the screen is usualy just whatever you set it to, not what the controlelr actually accepted.
amberwolf said:It's also possible for manufacturers to program the controller in a way that they cannot be altered after that by the user (or even the manufacturer).
I'd guess that's what you have there--a non-programmable version of their controller.
BionicBlitz said:For anyone looking i just found out you can half bypass the phase sensors and trick it into putting out more power. leave the wire in it but solder on an extra wire roughly the same size and go around (not through) the sensor and itll put out twice the power, all your setrings still work but you need to keep in mind its really putting out double of what it says on the app :} Thanks to everyone that tried to help though
