Hi guys,
I’ve got a simple question that’s proved difficult to find a solid answer to. Hopefully someone can quickly steer me in the right direction.
I’m using a Flipsky VESC to power a roller drive MTB build. Using ADC1 for throttle is working fine, but I want to get ADC2 working as a regen brake. So far it’s been behaving strangely and shutting down with both connected, and braking effect is notchy and minimal. Currently ADC1&2 are sharing the 3.3 and Ground pins on the sensor port. I’m using “Current No Reverse Brake ADC2” setting.
Recently I bought a Flipsky UART Bluetooth module, and noticed they suggest pinching 3.3v and Gnd from other ports - so not to share any connections with ADC1?
So i wonder - is splicing both ADCs onto common 3.3v and Gnd a no no? or is this method fine, and I should look for bugs elsewhere such as my VESC settings, connections, etc?
Thanks in advance for any wisdom.
