Inwo
I have a motenergy 3031 Pmac. Rated at 5,000 rpm max.
Is one of the limiting factors heat? Or can it be programmed to run cooler, at reduced power.
Motor is over double hp needed.
A buddy has run it 7000rpm and it survived. The only issue is 100C after a few fast miles.
I've been told that the heat is from pushing rpm over design limit. Can this be compensated for, or is a gear change required?
