Cheap FOCer 2 (Open-source, Low-cost, VESC 6 based ESC) (Prototyped. Materials have arrived for a test batch)
marcos   1 kW
Re: Cheap FOCer 2 (Open-source, Low-cost, VESC 6 based ESC) (Prototyped. Materials have arrived for a test batch)
Post by marcos » Jan 31 2020 10:41pm
Slowing down the switching won't hurt much if you don't use very high switching freq like 25+kHz. High end VESCs often switch at 25 or 30khz because the observer works better with more sampling per second, but you can halve that by sampling on both V4 and V7.
Its important to take a look at the gates voltages to make sure miller capacitance is not turning ON your mosfet due to high dV/dt.
With high power stuff its not a problem because gate driver OFF is like -8V, you are far away from a turn on (Vth=3V for example).
But cheap gate drivers turn OFF with 0V, and with an Rg!=0 so they kind of suck holding the gate OFF. Small fets can turn on at only 2.5V so its worth taking a look. If it fully turns ON you get a shoot through!
The 50A waveform looks great!
Does your project need a high performance motor drive? Let's talk!
www.powerdesigns.ca
Do you like our work? Follow Axiom!
shaman   1 kW
Post by shaman » Feb 01 2020 9:27am
Thanks @marcos!
Yeah these little TO-220 FETs can turn on at a minimum of 2V. I'll check out the gate voltage waveform to see whats going on and I'll post that. I figure I can increase the gate drive resistors a bit and also add a small capacitor from gate to source if need to be if the gate drive signal is noisy.
peters   1 kW
Post by peters » Feb 01 2020 11:29am
Very nice waveforms, indeed!
The overshoot (spike) at turn-off is absolutely normal, because the current changes from 50A to 0 during that time and the overshoot voltage above the DCbus is L*di/dt. L is the output loop inductance that is an inherent attribute of the circuit.
In fact the area under the overshoot (between the 2 dashed lines) is the flux in that inductance (=L*I), that is always the same for the same current. If you reduce the overshoot by half then its duration would normally be twice as long, so it's a trade-off.
Which FETs are you using on this board?
marcos   1 kW
Post by marcos » Feb 01 2020 12:25pm
During double pulse test you want to look at the gate that is kept always off. Here you can see how the gate turn on looks like.
Also, when you make RgOFF larger (slower turn off, less overshoot) you are making miller turn on worse because driver loses strength to keep the gate at 0V, so its not a single knob tuning.
www.powerdesigns.ca
shaman   1 kW
Post by shaman » Feb 01 2020 1:01pm
peters wrote:
Feb 01 2020 11:29am
I'm using the CSD18536KCS. I looked at the wrong datasheet earlier. The minimum turn on threshold is 1.8V
http://www.ti.com/product/CSD18536KCS
I also want to test with the NCEP60T20. It's a cheap FET that seems like it could work decent enough
https://lcsc.com/product-detail/MOSFET_ ... 84868.html
@marcos
I'll be looking at the consequences of everything I try. I figure increasing the rise time to anything under 200ns would be ok. I'll keep an eye on the gate voltage waveform.
SRFirefox   100 mW
Post by SRFirefox » Feb 01 2020 1:22pm
shaman wrote:
Feb 01 2020 1:01pm
peters wrote:
Feb 01 2020 11:29am
I'll be interested to see what your results are. Based on my math, both FETs should be able to handle close to (or even over) 100A phase with good heatsinking, assuming you don't spike over 60V of course. Here's hoping you might achieve something close to that.
zombiess   100 MW
Post by zombiess » Feb 04 2020 1:01am
SRFirefox wrote:
Feb 01 2020 1:22pm
In one of my own thermal tests I found the max limit in near optimal conditions is about 40W of waste heat from a TO-220 package. That's a TO-220 with NO INSULATOR, a super thin layer of thermal paste on a copper heat sink from an old Xeon processor with a high flow fan. This was for steady state operation where the case temp did not exceed 80C in a 26C environment.
With an insulator it's more like 25W of waste heat the package can withstand before thermal runaway.
Your mileage may vary.
Pinski1   10 µW
10 µW
Post by Pinski1 » Feb 04 2020 3:39am
zombiess wrote:
Feb 04 2020 1:01am
In one of my own thermal tests I found the max limit in near optimal conditions is about 40W of waste heat from a TO-220 package. [..]
Do you have dissipation numbers for the TO-264 package? I wonder how easy they'd be to add to this form factor.
shaman   1 kW
Post by shaman » Feb 11 2020 11:46am
CFOC2 side.jpg (183.52 KiB) Viewed 1235 times
FOCer sammich. Shows the way I mounted the FOCer to the heatsink. M3 screws, 4.5mm 3D printed spacers, and 0.5mm silicone thermal pad.
CFOC2 5V.jpg (253.95 KiB) Viewed 1235 times
Auxiliary 5V for fan goodness. Yes the connectors on the PCB are burnt/melted (don’t ask). You can also see the springy thing I made and soldered to the PCB for low-inductance measurements of the switching waveforms I posted earlier.
CFOC2 fan.jpg (205.16 KiB) Viewed 1235 times
50mm 5V fan and aluminum heatsink from AliExpress. Fan mounts with M3 screws with screws self-threading between heatsink fins just right.
Ok so now I finally mounted a heatsink to this thing and collected some thermal data. It was a crude test and my test setup is ery limited but the numbers seem decent
20A FOC with fan
Start 20C. Leveled off at 28C
20A FOC without fan
Start 25C. Increased to and leveled off at 38C in 10 minutes. Stopped cause I got bored
50A FOC without fan
25C to 50C 2 minutes. Stopped cause motor was getting hot
50A FOC with fan
25 to 49C in 3 minutes. Creeping at 0.1C per 5s. stopped cause motor got hot
Ambient temp was about 20C. This isn’t great data but its something for now. I’d say the heatsink and fan do a decent job.
SRFirefox   100 mW
Post by SRFirefox » Feb 11 2020 6:52pm
Very cool. Those numbers look pretty darn good too. You could dunk your motor in a tub of water to keep the heat down for the 50A test. 25 to 50C in 3 minutes with some good airflow is some pretty good numbers for general bike usage.
shaman   1 kW
Post by shaman » Feb 11 2020 11:02pm
SRFirefox wrote:
Feb 11 2020 6:52pm
I don't know man. How do I know everything is waterproof up in that motor?
zombiess   100 MW
Post by zombiess » Feb 12 2020 12:24pm
shaman wrote:
Feb 11 2020 11:02pm
By running it underwater of course! Motor runs = waterproof, motor fail = not waterproof :mrgreen:
thepronghorn   100 W
Post by thepronghorn » Feb 18 2020 3:50pm
shaman wrote:
Feb 11 2020 11:02pm
SRFirefox wrote:
Feb 11 2020 6:52pm
Check phase resistance and insulation resistance. Submerge motor. Repeat measurements.
shaman   1 kW
Post by shaman » Feb 18 2020 8:31pm
I think I'm going to bypass potential issues with water and submerge in mineral oil instead. I have a different thread where I'm discussing that in more detail.
marcos   1 kW
Post by marcos » Feb 19 2020 12:58am
Distilled water is orders of magnitude less conductive than tap water. If a powerful fan doesnt cut it, or if the dyno doesnt fit in a fridge I would give pure water a try. Mineral oil isn't as great moving heat away, and its messy.
Maybe rub a bit the motor with alcohol to make it extra clean so it doesnt contamine the water. If you are adding ice it should be from pure water as well.
Or just use tap water and rely on the protection mechanisms of the controller.
Either case, watch out for cavitation at high rpm, the bubbles collapsing can do some damage over long times, and air pockets aren't good moving heat away.
www.powerdesigns.ca
shaman   1 kW
Post by shaman » Feb 19 2020 2:53pm
@marcos thanks for the tips here. My fear is of the water becoming contaminated over time in a garage environment and becoming more conductive. I’ve thought about having the motors in a metal tub submerged in mineral oil. Then having that tub placed in a larger tub that is filled with ice water for enhanced cooling. Maybe my fears with water contamination isn’t justified but I can’t help but think that will eventually have problems
SRFirefox   100 mW
Post by SRFirefox » Feb 19 2020 3:31pm
Somewhere in Vedder's testing videos he has pictures of a turnigy outrunner testing underwater. Distilled and deionized water is inexpensive from the grocery store, so it wouldn't be difficult to swap out water. And as Marcos pointed out, it's not terribly conductive anyway. Best way to remove the water from the motor would be to keep running it after unsubmerging it and letting the heat bake the water out. I do this with medium voltages and power resistors when I don't feel like buying more resistors or it's expensive to actually get the appropriate dissipation for the test load.
shaman   1 kW
Post by shaman » Feb 25 2020 1:52pm
CFOC2 betas.jpg (334.77 KiB) Viewed 829 times
Beta batch in progress
CFOC2 betas 2.jpg (386.63 KiB) Viewed 829 times
2 beta units. One with phase cables soldered in from the underside
Working on it.
shaman   1 kW
Post by shaman » Mar 05 2020 11:00am
Cheap FOCer 2 order.JPG (49.4 KiB) Viewed 603 times
Still working on the beta units but I've also ordered a prototype of the latest revision. The latest revision has an IMU, minor improvements to the gate drive, optional pullup/pulldown resistors on the ADC channels, and a wider PCB now at 60mm. The wider PCB fits the intended heat sink nicely with the mounting holes now aligning in between the fins. This way drilling is easier and the screws will fit nicely in between the fins.
shaman   1 kW
Post by shaman » Mar 16 2020 8:52am
Beta unit batch.jpeg (347.05 KiB) Viewed 435 times
Almost done with the beta units.
Also the newest rev should be in today. It should functionally the same plus the IMU capability.
shaman   1 kW
Post by shaman » Mar 18 2020 8:47am
cheap focer 2 new rev .jpeg (303.23 KiB) Viewed 348 times
New rev arrived. Will assemble this and put a scope to it like the other. I made some small gate drive improvements so I want to see if that made a difference. I also want to optimize dead time. Dead time can be set with hardware or firmware. My controller switches a bit slower (on/off rise/fall times) than the original VESC 6 so I figure a bit more dead time is needed.
