george williams
10 µW
- Joined
- Dec 2, 2019
- Messages
- 5
correction...will not run motor properly. runs at idle speed only and when throttle is set the slow running moves from max to min throttle position. also cellcount is 4 beeps. shouldnt i hear 20 beeps? 90v flier brushless esc will not run revolt rv100 motor on 80v cobalt battery. motor runs fine on 24v battery and is rated 24-96v. should esc program be changed from lipo battery to life battery? I'm using a servo tester for throttle. thanks for help
