RoyFirewall
- Joined
- May 7, 2020
- Messages
- 10
I wanted to get opinions on this motor. It's a new motor from QSMOTOR and appears to be a 212mm diameter motor, 35mm wide. Steel core. Per QSMotor this motor is replacing the 205 35h.
#Aliexpress US $114.00 | QS Motor 1200W 212 35H V1.12 electric bike spoke hub Motor/bicycle spoke motor/Low power electric bike
https://a.aliexpress.com/_dTOWsMP
I'm inquiring if it has .35mm thin laminations. I did ask how many poles and the answer was 26.
It apparently fits 135mm drop-outs, and has 25mm threads for up to a 3 gear freewheel.
Single Hall and no temp sensor.
The reason I was interested in this motor was because of the 9C RH212 from Grin. The larger 212mm diameter supposedly gives better torque. The RH212 seems to be a very good motor on the simulator.
I figured if the QSMotor is using the same 212mm configuration but with a 35mm stator, it could be motor with decent performance.
The 35mm stator puts it into being similar to a leaf 1500w but coupled with the larger diameter and additional poles.
