Lishui "Open Source Firmware" project / KingMeter 5S
AndZab
Hello, I'm interested to this Lishui Project:
https://github.com/stancecoke/LishuiFOC
I'm searching description of KingMeter 5S protocol, the standard for 850C display coupled with Lishui.
Inside this project I found useful sources: display_kingmeter.c and display_kingmeter.h
But I'd like to know if somewhere exists text documentation for this 5S protocol.
I found also the project discussion on pedelecforum.de but it is in german and I know only english and italian.
Maybe exists here an english thread for this project ?
Also do you know other display projects using 5S ?
Thanks
(Note: I found 5S traces also inside Kunteng Open Project, but not sure about difference between KM5s, EBS-LCD2, J-LCD, SW-LCD)
I took the basics from the "Forumscontroller", but the KM5S protocol is quite tricky, as it needs an encrypted handshake at startup. The lookup table from the Forumscontroller code didn't work for me, so I had to "spy" the right answers from the original Lishui firmware. The most recent code is in the sensorless branch, I added the "Fischer" display there
https://github.com/stancecoke/LishuiFOC/blob/Sensorless_VESC/Src/display_kingmeter.c
I don't know a text documentation, only the comments on the code of the Forumscontroller.
The J-LCD protocol is much easier, but it's hard to get a display, that uses this protocol.
regards
stancecoke
regards
stancecoke
Hello stancecoke, thank you very much for your remarks.
I really like Lishui controllers, much more then Kunteng.
I'd like to test this Lishui Open Firmware, and I think I will begin from the beginning...
First thing to do is to setup the new development enviroement, and test fw "as is" now.
Then I will eventually think about new features...
It's arriving to me a new Lishui controller 12 MOSFETs, with 860C display.
It seems board will be LSW12G... something.
Bafang hub motor for testing is G060.750.DC
I'd like to test the open fw by uploading on display connector.
This is because I don't like to open the sealed case (don't have ST-Link, too)
Just have USB-Serial TTL Higo adapter.
Sadly, all connectors are Higo/Julet waterproof, so rewiring not possible at all.
I have a few questions for you:
- Any risk to erase board bootloader, when updating by display port ?
- Any fw modifications needed to adapt the motor ? Is the Configurator enought, in your opinion ?
- Do you think it's a good idea to open here a new thread for the Lishui project ? I would appreciate if you can do it.
- And last but not least, any suggestions are welcome !!
Thank you very much for your help, hope to eventually do some contributions, if I will be able to learn enought...
Apart displays, I have some ideas about the throttle...
Regards
I hope it's a "F" in the product number. Otherwise the controller is not suited for the Firmware. Where did you buy the parts? Is it a bundle?
fetch.php
I've documented the project mainly in the german wiki:
https://www.pedelecforum.de/wiki/doku.php?id=elektrotechnik:eek:pen_source_firmware_fuer_lishui_-controller
I don't know how much resonance the project would get here in this forum. There is just a handful of users in the german forum.
regards
stancecoke
Yes, I can find a "-F-" in the product code. It's a new model powerful controller, bundled with 860C. Don't ask more :mrgreen:
Sadly, I don't know german language :confused:
Without interaction with other people, it's difficult to bring ahead anything.
Lishui controllers are much better then Kunteng, in my opinion. They have bootloader.
They are powerful, STM32 and not STM8. Also they are smaller, to fit in my frame.
I have big problems to find a small waterproof Kunteng, 48V sinewave, 25A, Octagonal plug for Bafang 750W, 1T4 or 1T5 harness.
Can you suggest some source ? It's 1 month I do queries on Alibaba, with few results.
Thanks a lot, Regards.
:thumb: Can you tell me the source? Per PM, if don't want to make it public...
That is no problem in times of google translate or deepl :wink:
https://translate.google.com/translate?sl=auto&tl=en&u=https%3A%2F%2Fwww.pedelecforum.de%2Fwiki%2Fdoku.php%3Fid%3Delektrotechnik%3Aopen_source_firmware_fuer_lishui_-controller
Only the ones with Bafang-Display have a bootloader as far as I know. Often the controllers have the programmer-connector for the ST-Link.
But you can flash the bootloader once per STLink and then use the Display-Connector for flashing. And yes, the Lishuis are much better than the Kuntengs, you can do real FOC, even sensorless, with them 8)
regards
stancecoke
I sent you a PM, hope you can read it!
But may I write in english on this german forum ?
regards
stancecoke
All modern Lishuis have bootloader, so you can send new fw by display connector. When you flash by display port, you can adjust a couple of parameters: (current limit and cutoff voltage)
Is the Open Software bootloader compatible with original Lishui one?
Can Open Software generate a compatible .LSH file, so I do not need the ST-Link ?
Thanks a lot - Regards
Yes, we use the Lishui bootloader and the .LSH files for flashing.
regards
stancecoke
regards
stancecoke
Thanks a lot. Externally reflash without to open controller, it's a dream, because you can update on the fly.
This means to do more tests, quickly.
(and no need for "alien" ST-Link)
Regards
Code:
regards
stancecoke
I am also interested in the project. Very interesting, but where can I get the Bootloader?
Regards
The bootloader comes with the original FOC Controller Firmware Update Software from Lishui. There a hidden functions in this tool, you have to click one of the buttons several times to activate this extended functions.
But you don't need the bootloader, if it's preinstalled on the controller, or you can flash via STLink, too.
regards
stancecoke
Yes, you are right. J Protocol is much easier than 5S. And for us, display with both J & 5S protocol is available.
Are your displays buyable for anyone, or do you sell only to OEMs / dealers?
Can you post a link to an online-shop?
regards
stancecoke
Yes, usually we provide directly to OEMs. But possible for after-sales service. Means if you are using our display and need some help, like a replacement, we'd like to help.
If you need for testing, please confirm the J or 5S protocol and pins definition for connectors, then I can also prepare samples.
Actually I don't need a new display, but in the german forum are frequent requests from users, who want to replace the simple OEM LED-display (eg. "Fischer" or "Prophete"-Bikes) with LCD displays. Or want to replace the stylish but small LCD display (I don't know, if it's a KingMeter product) with a bigger one.
fischer-e-bike-mtb-montis-2-0-2019-perlweissy-matt-275-rh-48-cm-hinterradmotor-4-4-360x360.jpg
https://www.pedelecforum.de/forum/index.php?threads/fischer-montis-2-0-led-display-tauschen-zu-lcd.64078/post-1217280
https://www.pedelecforum.de/forum/index.php?threads/rex-graveler-e-9-6-vs-8-7-aeg-easy-display-vs-multifunkionsdisplay.63097/post-1194279
They will be happy to have a source for the alternative displays, I think!
regards
stancecoke
Usually if the original display in ebikes is LCD(LED), then it's easier to change into LCD(LED). But if LED change into LCD, there would be more parameters shown on the display, means we need more testing. So we can not provide for personal. As for Fishcher & Prophete, it's all customized display. Sorry we can not change it per each rider's request.
Hello! And have I understood right? - Do the original Lishui controller use 5S UART protocol?
I'm looking for a small display for my Lishui controller to exchange the huge SW900. KT-LCD4 is the best in size, but don't work with the "stock" Lishui. SW-102 from Wuxing (Star Union / Topology) is 2 times more expensive, but also don't work with Lishui "from-the-box". And it also haven't possibilty to set up parameters by display, like LCD4 with KT controllers or "big" SW-900 with Lishui. DZ30 and DZ40 from Wuxing (Star Union / Topology) is also candidates, but I guess, that they also will not match.
What protocol needed for matching and correct work with "stock" Lishui? 5S or J-?
regards
stancecoke
There is no "the Lishui controller". Lishui supplies OEMs mainly and has many many firmware version with various display protocols.
But if you are using a SW900 actually this should use the KM5S protocol. If you want something small, you can use this tiny Key-Display
It's sold as EBS Nano in Germany.
This uses the KM5S protocol, too. But no guarantee, that the handshake works. You can set the parameters as used from the SW900
regards
stancecoke
index.php
Hi Everyone,
I have an e-bike with a Lishui LSW772 sensorless controller. I wanted to flash this controller with the open source VESC firmware. I know that this branch is more experimental than the master branch. I took a little bit longer than expected because I'm not really familiar with this software. A lot of trial and error but fortunately I could build and flashed the controller. Now I have another problem. I use SW900 as display and I get an error code 10 (I believe it si a communication error). Attached are Eclipse console log and config.h. Any help will be appreciated.
Regards
Cencen
  • configh.txt
  • Eclipse console.txt
you have defined no display, as all relevant lines are commented out.
Delete the two slashes before #define DISPLAY_TYPE DISPLAY_TYPE_KINGMETER_FISCHER_1822
Perhaps you have to use an older commit, as my display changed the startup procedure one day for some reason.
regards
stancecoke
I added the missing display type line as:
#define DISPLAY_TYPE_KINGMETER_618U and also #define DISPLAY_TYPE_KINGMETER_901U
I tried both one by one, I got the display working but I still get the error 10 on SW900 display.
I checked your older commits but I don't know which one to use. Am I doing something wrong or
is this another problem rather than the software? What are other DISPLAY_TYPE DEBUG_SLOW_LOOP and FAST_LOOP?
Thanks and regards,
Cencen
  • config.h
?! There is nothing missing.
Just do what I wrote! Delete the two slashes, whyever you set them...
https://github.com/EBiCS/EBiCS_Firmware/blob/44791d56be94863a55cac56525487a8996753f34/Inc/config.h#L13
If this doesn't work, copy the display_kingmeter.c from the old commit of 26 Oct 2019 to your workspace. (simply overwrite the recent one in your workspace)
If you don't want to use a torque sensor, you have to comment out this line:
https://github.com/EBiCS/EBiCS_Firmware/blob/44791d56be94863a55cac56525487a8996753f34/Inc/config.h#L23
regards
stancecoke
First of all, I think there is a misunderstandig related to the display type. I was surprised and a little bit dissapointed with your unexpected reaction. I don't understand your frustration but I believe there was no need for that. As I told you I have a SW900 display which I thought is compatible with (KM5s, EBS-LCD2, J-LCD, SW-LCD) an that is why I tried DISPLAY_TYPE_KINGMETER_618U and DISPLAY_TYPE_KINGMETER_901U not the DISPLAY_TYPE_KINGMETER_FISCHER_1822. I did'nt realize you specifically ment to use it.
Anyhow I did everything you have written but unfortunatelly the result did not change. I am starting to believe this is a hardware problem (most probably the controller is faulty!). I had checked all cables, connectors but check it again thoroughly.
Lets leave this here. Thank you very much for all your help.
Regards
Cencen
No problem.
I never had a SW900 display, so I don't know which protocol it uses. The Fischer bike uses a SW LCD.
http://www.king-meter.com/#/product/10
If you have an USB-UART converter you can try to flash with
#define DISPLAY_TYPE DEBUG_SLOW_LOOP
Then TX of the controller sends constantly @9600 BAUD
If this works, you can try the display_kingmeter.c from the master branch. There the handshake procedure is optimized. If this still doesn't work, your display may use a different encrypted handshake, or a completely different protocol...
regards
stancecoke
