Truckrun middrive
cheapcookie
Hey with all the development on the tsdz2, does anyone know what I can do to my truckrun middrive?
I will compile help from others and research here!
Thanks alot!
I just bought a truckrun mid-motor m05, 36v 350w and i just wrote a blog post (in french) about it.
Truckrun said me the speed levels are not correctly programmed because level 1 (of 5) use 40% of the motor power.
Default programmation is :
« Level1 40%, Level2 60%, Level3 75%, Level4 80%, Level5 100% »
The motor should be programmed but i need the programming tool.
They said me you can but it from
https://www.fahrrad-elektrik-seger.de/
My blog:
https://geekborg.blogspot.com/2020/07/test-du-kit-electrique-truckrun-m05.html
