Hi guys. I have a problem with my motor, it was sensorless one but i needed one cheap and fast so i bought one online and took it upon myself to add halls.
After searching ive found person who modded similar unit, ive did the same thinking it will work but there a catch, after adding halls(motor still runs withot them) and after searching for correct wire combo ive found few working almost fine but it feels like one of the halls is in the wrong place? It runs little rough and wibrates at lower speeds.
@Edit
No halls connected to controller, motor sucks 0,76 amp, with halls connected in somewhat good combo draws 1,78amp and the better combination draws 1,45amp and its still rattling with throttle on lower speed on no load.
Sparta Ion front hub motor 20 magnets with 24 coils.
Halls added -
SS41 HONEYWELL hall sensors added in 120 degree phase angle? in star configuration all facing the magnets. Ive tested them with leds and all light one after the other(search on youtube adding halls to alternator and at the end of few vids you can see testing with leds)
Controller is a cheap ebay one 26v 250 still works fine tested on my similar motor to my previous broken one.
I need help determining if i added halls in correct places with correct orientation? meybe middle one needs to be turned around to get 60 degree angle?
Need help Thanks.
@Edit 2
I've turned around one of the halls and controller didnt see hall connected at all, ive tried 2 different controllers and i did the led test all leds blink one after the other with 2 staing up at a time but one always ligh up alone so i think something is wrong.
@Edit
Halls added -
Need help Thanks.
@Edit 2
