Sparfuchs
- Joined
- Nov 22, 2020
- Messages
- 305
Hello EV friends,
Recently i ordered a mxus 3k turbo in a 26" rim and a okfeet 1500w hubmotor in a 20" rim.
The problem is that both of the motors wobble around the axis. The biggest problem is that this also makes the break disk wobble and difficult to use. Another problem is that the motor "vibrates" at higher speed. Since i have no other motors yet to compare and the two motors have the same problem although they are different products from different manufactures, i thought this might be a common problem ? Is this normal and just a standard chinese quality or a unlucky production fail on both motors ? Does the qs205 also wobble a bit or is this better quality ?
Nevertheless i'd like to repair them. Do you have an idea if there is a proven method ?
I couldn't upload a video...any hints ?
Thanks for your help
Best regards
Sparfuchs, vienna
Best regards
Sparfuchs, vienna
