S06B and S12B controller wiring
Has anyone tried these new models sold by BMSB
https://bmsbattery.com/home/1133-18562-s06b-20a-sine-wave-controller-36v.html#/319-display-no_display
I have the S06B and the TF-200 display with throttle and no idea about the correct wiring
Display 6 wires
  • Red (5V+)
    Black (GND)
    Blue (Lock)
    Green (RX?????)
    Yellow (TX????)
    White (Gas signal????)
Controller, meter connector according to "description" has 5 pins:
  • White
    Green
    Black
    Blue
    Orange...
I have already sent an E-Mail to BMSB, with little hope to receive an answer
Has anyone tried this product combination or an idea how I can find out the correct wiring without the risk of destroying the controller in the process?
Update: BMSB has sent me an E-Mail
Dear Customer,
You will get a piece of Conversion line more.
Regards,
Customer service
Leaving me clueless...
At the moment I cannot recommend to buy the "B" controllers, as long as the vendor does not provide a detailed wiring diagram and instruction how to connect to the display. These controllers are useless without the display because the throttle is part of the display, and the display manages the speed levels as well, so that you would start with a random setting, if you find the throttle signal output on the board and solder the throttle signal cable directly to the board.
Update: I received another E-Mail today
Dear Customer,
you will find how to connect after get our controller
Regards,
Customer service
I found this for mine.... Hope it helps
