Tp100 20kw+
andrewgreene
Question regarding the tp100 motor as seen below, apparently it puts out 20kw+ which is really impressive, is there any other motor that's about that powerful and that size for cheaper?
http://www.tppower.com/sort.asp?class_id=4&news=110
I don't know if you're actually going to be able to get 20kW out of that motor for extended periods of time. Looking at that datasheet it looks like the combination where they get that is 170V at 138A; I'm not sure if the bearings can handle that (nor am I sure that the copper fill can do it; the motor is just slightly bigger than the venerable Turnigy C80100, which you can get 7-10kW peak, 2-5kW continuous out of without blowing anything up. If you want 20kW plus, then you might want to look at something bigger; it's a pity the RV120 and RV160 turned out to be of questionable quality because otherwise they'd fill that niche. You could also reach out to madin88 and see how his Neumotor 8057-based bike is running (and how much power he's safely gotten out of it).
