andrea_104kg
- Joined
- Mar 5, 2018
- Messages
- 344
bought a 48v tsdz2 from pswpower last week.
Unfortunately I opened it, to put the pads, and the double bearings on the right and left and I also installed a temperature sensor, not connected to the control unit, making a small dig in the crankcase to pass the wire. This is assuming the engine was running ...
last Sunday morning I left for a ride and after I stopped in the shade ... it never started again ...
comes on but the torsiometer does not work. Before the walk worked and the accelerator.,now they have both stopped working.
The control unit emits a slight whistle ... and the whistle passes when I disconnect the two wires of the torsiometer. What may have happened?
I tried with original firmware, with 20 01b and 20 01c1 3 but no results, no error on display
Obviously pswpower doesn't answer I ask for impossible things, like a video of the broken torsometer ...
I am depressed and angry, even buying the pieces they would arrive in September and frankly I am not interested in September ...
