ninetyeighter
100 µW
- Joined
- Jul 12, 2021
- Messages
- 8
Hi all,
To start, I am completely new to this world. With that said:
I have a 3-wheeled 48v EV that uses a master-slave Sevcon Gen4 configuration (S2 36/48V 275A AC Motor Controller). The company that made it is out of business and I am trying to connect to the CAN bus. I have an Arduino UNO and the SeeedStudio v2 CANBus Shield and am using the Twizy-Cfg project to connect. I had to modify the code to use CAN pin 9 instead of 10, otherwise is repeatedly tries to connect. Once I switch to 9, it seems to connect and I get the menu in the serial monitor.
I have a DB9 to USB since the EV takes a USB connection. I was able to connect this way as well as the direct CANHI/CANLO connections on the shield. That is where my luck ends. No matter what commands I send, I always get the SEVCON OFFLINE response. After some digging, I thought it could be a CAN termination issue and I cut the P1 pad connection on the CANBus shield. I know for a fact that the company used to modify the Sevcon configuration using the Sevcon's Calibration programming tool (as opposed to the DVT software). I read the calibration tool's manual and see that it assumes that the master/slave configuration is terminated and that the calibration tool doesn't provide termination. So, I feel like I should be able to read the Sevcon name, or put it in to pre-op mode, etc.
I've also tried various versions of the CAN library that Twizy-Cfg uses and some of the basic examples for receiving CAN messages. No luck.
I'd love any troubleshooting suggestions or help. Given my almost no experience with this stuff, I am at a loss as to what the next step should be.
Also, here is a diagram I was able to track down to show the CAN Bus wiring on my EV.
Thanks,
NinetyEighter
Thanks,
NinetyEighter
