Freddanson
Hi!
My knowledge when it come to problems with controllers and encoders is quite limited so and wonder if it's possible to get some advice in this matter?
Have changed the Curtis controller on my Bad boy buggie to a Kelly KAC7275H. According to the android app for programming the Kelly, there should be alternating (toggling) signals for three hall sensors (A, B, and C) when you move the motor by hand. I only have it on A and B.
There is an inductive encoder with four wires: pos, neg, signal A, signal B. My question is if I can signals on all three hall sensors with just two wires for the signal from the encoder on the motor?
Have tried with a new encoder and also changed the wires, but the problem remain.
Regards Fredrik
Regards Fredrik
