mxlemming
- Joined
- Jul 17, 2020
- Messages
- 1,116
I bought this from ant innovation technology. Similar ones are available from freerchobby etc but Arvin at ant was very forthcoming and useful so got the business.
Quick write up as requested. Not yet on my bike, that'll come later.
Copper fill is not huge, but the resistance is low and this does allow air flow so maybe not so terrible at it looks. The primary losses in this seem to be iron losses. Hall sensors installed and seem to be fairly regular in preliminary investigation.
It's big compared to an 8080 motor
But only twice the weight at 2375g (3d print weighs nearly 100). 8080 motor weighs 1156g. The other 8080i have is about 1250g.
VESC finds 10mohm and 7uH inductance... My MESC finds slightly lower but basically comparable. Ant measured 19mohm phase to phase which is meant to be double the single phase measurement vesc does.
Edit: new 5.03 VESC firmware finds nearer 20uH. Substantial difference. New VESC firmware far far more reliable and generally better so I'll have to investigate this.
The back emf waveform has quite a lot of 5th (edit 11th?) distortion, which makes it a bit hard to drive but VESC does ok in unloaded bench tests. MESC also runs it ok but struggles to control the d axis current.
Windings are fairly tidy and the shaft is a custom I drew and Arvin had made for me. It looks to have been hardened. No significant quality issues.
Free running power is 63W at 1300rpm (24V)and about 180W at 2500rpm (45V).The 8080 motor is about 1/3 of this. Strangely, the heat seems to be being generated in the rotor, which seems to get hotter than the windings and core. This is very provisional, I've not run it for long. This might be an artifact of it being quite tricky to control and inducing high frequency components in the rotor.
The biggest downside is the noise. It's got a fairly loud whine that's present in BLDC and FOC mode. Not sure what's causing this yet, the cogging torque is low.
14PP (28 magnets) 118mm diameter.
I requested the 8 turn 62kV option. The kV has come out nearer 57... Close enough.
The fixing screws are annoyingly m4 not m5 like every other RC motor in the world uses.
Overall looks promising. Waiting for the mounting bracket.
