help, emax hub motor with damaged wire harness.
so I bought a 72 4000W emax/proud eagle hub motor and the wiring harness was damaged in shipping. i was wondering if anyone can point me in the right direction how to replace the harness i would be grateful
Re: help, emax hub motor with damaged wire harness.
Post photos of the damage for users here to see what can be done.
https://imgur.com/DM9OVtv
https://imgur.com/CqL6CTR
as you can see at least one wire was cut and i cant tell how damaged the rest are
I would VERY carefully peel/cut away the outer black insulation up to where it enters the axle. Repair the broken and damaged wires and insulate it again.
