TysonScott
- Joined
- Mar 17, 2022
- Messages
- 89
Does anyone know if a zero 75-7 will work with the mobipus 72600?
Another, including levels of access in a chart, where all you have access to is the stuff with an O in it (an X means you can't access that without that level's password specific to that software). So as a user, you cannot tune a controller to work with a specific motor (if it works out of box, great...if not, you have to get distributor-level access).Dui said:Good luck with Mobipus.... Their password system is a huge pain.
I can't remember for sure what were the passwords. Something like "Mobipus" was unlocking the "user Mode" (whatever that was, not sure it will be enough for you but as I recall you would be able to set a few parameters, like throttle, current and some other stuff. Very limited though), but then you had two other levels to mod various settings, and for those you had to ask the Mobipus guys so they would give you a password valid for one hour... Complete nonsense.
That's one of the reason their company isn't stable and will probably go down, the product itself isn't bad, but how they manage it is completely stupid.
Anyway, if you want to get it to work you absolutely need to get in touch with their customer support.
romelec said:Here are the differnet parameters for each level, from the documentation I took from SamD website a few months ago.
In the files there was also a TeamViewer installer, why do they want to take remote control of the PC running the software ?
The asterisk is not defined in the spec but I guess the access level is configurable, so a user access for regen might be possible.
For direct sales that they want to do, they need to provide ~~at least an unlimited distributor access (with brake & regen)~~ a full access and of course without internet requirement.
Web Server's Default Page
This page is generated by Plesk, the leading hosting automation software. You see this page because there is no Web site at this address.
You can do the following:
Create domains and set up Web hosting using Plesk.
TysonScott said:Does anyone know if a zero 75-7 will work with the mobipus 72600?
Doctorbass said:Btw i'm converting the 75-5 of my 2013 ZERO XU to Hall sensor with that RMB29 pcb that i already have. This is for my XU converted to FX
Dui said:TysonScott said:Does anyone know if a zero 75-7 will work with the mobipus 72600?
No Idea for your specific question, sorry, but all I know is that you should avoid Mobipus, unless you got the passwords somehow (in which case please be nice and share it to the world XD).
But, good news maybe, I know for sure the Nanjing FarDrive can work with your motor, if you ask NanjingFarDrive to make it specifically for a sine/cosine unit. It does exist and I actually got one unit sitting here in the shop.
These controllers are even better than the mobipus, the one I got here can go up to 1800 Amps per phase but some less crazy options exist in their lineup :wink:
TysonScott said:How much are they? how big? the main reason i was looking at the mobipus 72600 was because the programming looked easer and had the dash build it. it also was small enough to fit in the airbox of a crf450. i had heard of the password system but i thought you just got on password to use it, but now that i found out its just for an hour, that is stupid. how big is the fardriver that you have? how much are they? thanks alot!
If i get the RMB29, and install it, then the motor would have hall sensors right? would it work with the FarDriver ND961800? are they hard to swap or is it just a quick job?Doctorbass said:The hall sensor that lifeforphysics talked about for the 75-7 are made by RLS and are model RMB29 i believe.
https://www.rls.si/eng/rmb29-rotary-magnetic-module
Part Number RMB29EE12BS66
Choose:
1) Commutation single end
2) 5 periods per revolution (10 poles).
3) 4096 points per revolution
4) Square
5) Push-Pull UVW with Molex
Doc
Dui said:It does exist and I actually got one unit sitting here in the shop.TysonScott said:Does anyone know if a zero 75-7 will work with the mobipus 72600?
