Dacflyer
Hi all, I finally found some magnets to repair a hub motor ( no info available on this motor )
48V Watts ???
has a 10" rotor 36 poles 32 magnets.
I thought it was missing a magnet, So hunting hi and low, I finally found a place that had the exact size i needed..
Today, I was excited to start assembling it all back..only to find ( thru learning ) that the gap was too small for the extra magnet.
I read somewhere that the magnets require some gap. Not touching.
So, i started looking around for some card paper, of different thicknesses. The thickest i have was a card paper that Del Monte cans come in.. I'm so close.. the sections really closed the gap. but right at the last/first magnet, there's still a gap that i can fit in 2 papers.
only other way to close the gap is to use regular paper with the card paper. that'll be really tricky to do...
would it mater much on motor operation with such a gap ? or should i just go ahead and add the paper + card paper to close the gap better??
Does this look ok?
48V Watts ???
Does this look ok?
