17 & 23s 150/200A controllers
ron van sommeren   100 W
Post by ron van sommeren » Jun 06 2011 5:36pm
Vriendelijke groeten ;) Ron
diy motor tipsDrive Calculator
diy motor groupCumulus MFC
Ratking   1 kW
Re: 17 & 23s 150/200A controllers
Post by Ratking » Jun 07 2011 7:16am
Looks promising , maybe someone rich and adventurous guys should buy a few and test them with different motors. Maybe they are superior to what we have today. That boat went fast no doubt.
Thank you for posting
Post by ron van sommeren » Jun 07 2011 8:09am
The 17s version costs less than 180$ :D :idea:
See
http://www.rcgroups.com/forums/showthre ... st18423317
flathill   100 kW
Post by flathill » Jul 09 2011 2:14am
bump
amberwolf   100 GW
Post by amberwolf » Jul 09 2011 2:25pm
Unless you have a specific question or reason for bumping the thread, I don't see anything in it that would need bumping after only a couple of days.
If you do have a reason or question, you ought to be posting that, instead of "bump". ;)
flathill   100 kW
Post by flathill » Jul 09 2011 4:16pm
bumped after a month not two days :)
could be a real high voltage alternative to the castle controllers in rc setups
beta testing of the 24s 260Apk controller is almost complete
18s 220Apk controller is in stock now
amberwolf   100 GW
Post by amberwolf » Jul 11 2011 7:48pm
:oops: Sorry, my bad--you're right about the amount of time....but still, asking something specific is better than just "bump" if there's no existing open questions. ;)
spinningmagnets   100 GW
Post by spinningmagnets » Jul 11 2011 8:10pm
I highly recommend watching at least one-half minute of the 16S boat video, brought a big smile to my face.
http://www.youtube.com/watch?v=OBTt_NZp ... e=youtu.be
Rated for 17S, recommended voltage is 16S. If using the 3.6V - 4.1V per cell protocol, thats 57.6V - 65.6V for the pack. It makes sense that the boat ESCs would have higher voltages available sooner than plane/heli ESCs. RC motors are typically terminated in Delta so they get the max RPMs per volt, Planes/helis are very weight sensitive, and going to a higher voltage can put a limit on how many aH's you can load the plane with, so...lots of RPMs from fairly low voltages. I'm guessing boats would be less weight sensitive.
Like most boat ESCs, this is water-cooled from the boats high-speed forward motion ramming the flow (*no pump), so...AJs computer liquid-cooling experience may be useful here?
At the 1:33 minute mark, I notice he's also using an outrunner with the recently-discussed water-cooled motor baseplate, they use two separate non-contact thermometers to verify the temps of the motor, controller, and batts.
edit: in the RC chat, there will be car versions with finned heat-sinks and possibly integrated fans. Be aware these are spread out for heat dissipation, one guy quoted approximately 6" X 3" (roughly 150mm X 75mm)
