5kw or 10kw Golden Motor HELP!
So, I've been attempting for about a month now to locate a sprocket that will fit the shaft of the Golden Motor 5kw or the 10kw setup. It's not the hub motor, it's these:
48 Volt 5000 Watt Brushless DC Motor (Golden Motor)
48 Volt 10000 Watt Brushless DC Motor (Golden Motor)
Model: HPM5000B
Volts: 48 volt
Watts: 5000 watts
Speed: 2000 - 6000 rpm
Weight: 24.2 lbs.
Case: Aluminum finned
Length: 5" (126mm)
Case Diameter: 8" (206mm)
Shaft Diameter: 7/8"
Shaft Length: 2"
Keyway Width: 5/16"
URL: http://www.monsterscooterparts.com/48v-5000w-brushless-aircooled-motor-golden.html
At least for the 5kw one, I wanted to locate a sprocket that will fit the shaft of the motor. Where can I find this? I feel I have literally looked everywhere, but it is simply too sophisticated for me. I feel like I have to go get a Masters Degree in engineering to figure this out, but I don't think I should have to do this.
Also, where can I find a 4 inch, possibly 5 inch in total diameter "Flat" sprocket that matches the one that I install on the Golden Motor?
My goal? I'm trying to install an electric motor under the hood of my 2006 Toyota Tacoma. I am trying to turn my truck into a "Mild Hybrid". I am going to mount the motor underneath the hood, with a chain that links to another flat sprocket that bolts ONTO or "IN FRONT" of one of the pulleys of the engine. The electric motor will simply "Assist" the Internal Combustion Engine, but by no means will it ever drive the car. Any ideas where I can find sprockets that will match? I'm lost. Golden Motor is even lost. Has anybody ever found a sprocket for these?
Best place to find inexpensive stuff like these. http://www.surpluscenter.com You may need to play with the key slots a bit.
12T
http://www.surpluscenter.com/item.asp?item=1-2123-12-D&catname=powerTrans
24T
http://www.surpluscenter.com/item.asp?item=1-2123-24-D&catname=powerTrans
cheers
You can get some high quality hardened sprockets for Golden Motors and Motenergy motors from https://www.ampsprockets.com
The guy that runs the site is a member of ES and Electric Motorcycle Builds on FB.
