I'm using a Q100H mid-drive for a customized utility bike. I had to cut down the axles, and in the process stripped a screw that then required complete disassembly of the motor to properly fix.
The motor seems locked up as I'm putting it back together. Notably, the planetary gears seem to be stuck - they're simply not rotating.
It makes putting the gears:
Into the side cover:
Very difficult, as the teeth don't line up. And I'm sure the motor wouldn't work properly!
I was careful to get all of the bearings (those under the planetary gears and over the sun gear) back in properly.
Any ideas?
Thanks!
Any ideas?
Thanks!
