mrfusi0n   1 µW
Re: TSDZ2 mid drive and 850C and SW102 displays only -- Flexible OpenSource firmware (Casainho code only)
Post by mrfusi0n » Jan 29 2020 10:26pm
casainho wrote:
Jan 29 2020 8:52pm
Previous, the motor current was always set to max value of 30 amps while the battery current was controlled. Now it is the inverse, battery current is always set to max value of 16 amps and motor current is controlled.
Looking at your feedback, maybe we should keep control the motor current BUT also the motor power in a way to limit the motor max power for it to be motor power = pedal human power * assist level factor. What do you think?
If so, then we would need 2 assist level factors for each assist level number:
1. motor current = human power * assist lever factor, for instance: motor current = 100 * 0.05 = 5 amps
2. motor power = human power * assist lever factor, for instance: motor power = 100 * 2.5 = 250 watts
So, I'm actually going to take back what I said before. Or, at least, I need to test things out a little more. It appears something was acting up a bit for one of my last rides - torque sensor? I saw "human power" spike to 1000, then 1500, then up to 3000! I never knew I was so strong! :lol: Not sure what that was but the power assist on my ride earlier today seemed much more linear and human power was back in the normal range the entire time:
https://docs.google.com/spreadsheets/d/ ... sp=sharing
I'm also re-reviewing electric motor concepts: torque vs electrical power vs mechanical power. Initially, I thought motor power = human power (or another direct ratio) would be ideal but it might not be that simple. Perhaps motor toque = human torque would be better? I think that's essentially what you have now since torque should be directly related to motor current.
Thanks for your hard work! I'll continue playing around with this and maybe gather some more data...
casainho   10 GW
Post by casainho » Jan 29 2020 10:33pm
mrfusi0n wrote:
Jan 29 2020 10:26pm
Yes, there seems to be an issue that makes human power to be measured +1000W sometimes. I still don't know what triggers that issue... the solution for now is to power off and power on again the system.
- TSDZ2 OpenSource firmware
famichiki   100 W
Post by famichiki » Jan 30 2020 7:10pm
Has anyone ever had a motor blocked error triggered by a sudden emergency stop, is that possible?
Now that I think about this, it was most likely a problem with the display attributed to extreme heat as no error code was shown and the display itself didn't seem to function correctly.
Powerhour   100 mW
Post by Powerhour » Jan 31 2020 9:14am
I noticed the shunt on the controller is a thin piece of metal, if i picked the silicon off the top and stuck a small bit of solder onto it would this be any way beneficial? I'm sure this has been done, I couldn't find anything searching so thought I'd ask here
eyebyesickle   10 kW
Post by eyebyesickle » Jan 31 2020 1:57pm
Is anyone using the experimental high cadence mode successfully? With v1.9 no one could get it to operate correctly to my knowledge... Always motor shuddering, especially any power over 200w. Now I see you can pick experimental 36v OR experimental 48v in the motor type under settings in the newest releases. Has the code been modified then? Anyone try it?
casainho   10 GW
Post by casainho » Jan 31 2020 2:02pm
eyebyesickle wrote:
Jan 31 2020 1:57pm
The code hasn´t been modified. Simple, the 36 and 48V experimental modes were available on previous motor firmware version but the display were only shown one of that modes.
eyebyesickle   10 kW
Post by eyebyesickle » Jan 31 2020 3:04pm
casainho wrote:
Jan 31 2020 2:02pm
eyebyesickle wrote:
Jan 31 2020 1:57pm
Previously, it only said 'expert' and did not specify a voltage. Which voltage was it for?
Have these modes been tested yet with the new version? I will try when I can becuase we had no success with previous versions... It always made a very bad sound and little to no power... This feature is the difference in the motor being useable or not for alot of people who have higher cadence/bursts, or live in very hilly areas and have to use low gears and spin faster, or the motor will overheat.
jeff.page.rides   10 W
Post by jeff.page.rides » Jan 31 2020 5:56pm
eyebyesickle wrote:
Jan 31 2020 3:04pm
casainho wrote:
Jan 31 2020 2:02pm
eyebyesickle wrote:
Jan 31 2020 1:57pm
I am using it on my 2 48 Volt Motors but I'm using version 20. The only difference I can see is that I can pedal up to a max of113 rpm and my arms can pedal a consistent 97 rpm both with power assist, were before with standard 48 the power stopped right at 90 rpm.
casainho   10 GW
Post by casainho » Jan 31 2020 6:19pm
eyebyesickle wrote:
Jan 31 2020 3:04pm
What I know is that the values on firmware were the ones choosen and tested by Jabalat.
Elinx   100 W
Post by Elinx » Jan 31 2020 8:23pm
casainho wrote:
Jan 31 2020 6:19pm
eyebyesickle wrote:
Jan 31 2020 3:04pm
Previously, it only said 'expert' and did not specify a voltage. Which voltage was it for?.....
Jbalat has tested the 36V values FOC angle 115 and MOTOR_OVER_SPEED_ERPS 700 for higher cadence the best settings.
maximusdm did tests for 48V and found FOC angle 220 and MOTOR_OVER_SPEED_ERPS 900 values are the best settings.
These last values haven't been added to the later releases, so eventually do this yourself. (motor.c and main.h)
amberwolf   100 GW
Post by amberwolf » Jan 31 2020 10:10pm
Powerhour wrote:
Jan 31 2020 9:14am
you can find general info in threads and posts about shunt mod / modding / modifications / soldering / etc.
but basically if the shunt value is not accurate, the controller has no way to protect itself or the motor or the battery from overloading, because it no longer knows what the actual current (or power) is anymore.
if the components are capable of handling the higher (but unknown) currents, then you get a boost out of the system (more power / etc).
but if they're right on the edge, or past it, with the higher currents, stuff fails (usually dramatically), and you get to buy new stuff. ;)
casainho   10 GW
Post by casainho » Feb 01 2020 2:05am
amberwolf wrote:
Jan 31 2020 10:10pm
Powerhour wrote:
Jan 31 2020 9:14am
Just use our OpenSource firmware were you can configure on the display any value for the battery current and motor phase current. And you will also get a motor with more torque and that uses less battery energy, meaning you can go higher distances with the same battery.
Post by jeff.page.rides » Feb 01 2020 4:34am
casainho wrote:
Feb 01 2020 2:05am
amberwolf wrote:
Jan 31 2020 10:10pm
Powerhour wrote:
Jan 31 2020 9:14am
I have a question, if we know what the most efficient setting and vaues are then why not set them there and not make them a just able? Or publish them and give the explanation of how and why? Everyone can take advantage of the most efficient system!
casainho   10 GW
Post by casainho » Feb 01 2020 4:54am
jeff.page.rides wrote:
Feb 01 2020 4:34am
I don´t understand you question and suggestion.
Our OpenSource firmware is the most efficient possible. Adjusting the battery and motor currents has nothing to do with the firmware being most efficiency possible.
There are a lot of reasons for user want to customize those currents but I should not explain here or I would be repeating and wasting my time, that way not being efficient - there are for sure a lot of information on internet for what reasons that currents can be configured.
skestans   100 W
Post by skestans » Feb 01 2020 5:47am
I really can't figure out how to build the flashing cable.
I have bought a display cable extension, I cut it in half, and I'm using that from the USB-TTL to the display.
I have tried supplying the 30V on the purple cable, or on the orange cable. In any case, the display lights up when long pressing the power button (like you would on the bike.)
I have tried having RXD on the USB dongle connected to the green wire and TXD on the USB to the white wire. I have tried swapping these so the dongle RXD is on the white wire, and TXD on the green.
In every combination, the display turns on when I long press. But when I connect it to the Windows software and short press power to flash, nothing happens at all. The software keeps trying, and nothing ever gets flashed.
It's driving me nuts. What is the issue here?
bikelpl   10 µW
10 µW
Post by bikelpl » Feb 01 2020 7:46am
Try connecting black wire also to to gnd on usb/uart module.
Powerhour   100 mW
Post by Powerhour » Feb 01 2020 8:15am
Yea it won't work without the groundpin connected, I overlooked that at first as well, when I flashed mine
skestans   100 W
Post by skestans » Feb 01 2020 8:32am
Powerhour wrote:
Feb 01 2020 8:15am
So GND in the usb is connected both to the power booster minus and to the black wire in the connector?
bikelpl   10 µW
10 µW
Post by bikelpl » Feb 01 2020 8:33am
skestans wrote:
Feb 01 2020 8:32am
Powerhour wrote:
Feb 01 2020 8:15am
YES
Powerhour   100 mW
Post by Powerhour » Feb 01 2020 8:44am
Feb 01 2020 4:34am
casainho wrote:
Feb 01 2020 2:05am
amberwolf wrote:
Jan 31 2020 10:10pm
Powerhour wrote:
Jan 31 2020 9:14am
Good answer! Haha thanks. (I kinda already knew the truth as well..) but also the truth is with my first one I 'teched it till I wrecked it' got this one, and the first thing I did was rip it open to modify/upgrade it, and before even thinking about it I beefed up the shunt and then repotted the hell out of it..like it was second nature something, ugh. Jesus. If I measured the new shunt value is there anyway to enter it somehow? Or is the math just going to have to all be screwed up now?
Thanks
skestans   100 W
Post by skestans » Feb 01 2020 10:05am
bikelpl wrote:
Feb 01 2020 8:33am
skestans wrote:
Feb 01 2020 8:32am
Powerhour wrote:
Feb 01 2020 8:15am
YES
Yeah, I totally missed that one after using an external power supply... and didn’t rewire GND. Thanks, for it working now.
Post by jeff.page.rides » Feb 01 2020 2:41pm
casainho wrote:
Feb 01 2020 4:54am
Feb 01 2020 4:34am
I have a question, if we know what the most efficient setting and values are then why not set them there and not make them a just able? Or publish them and give an explanation of how and why? Everyone can take advantage of the most efficient system!
Sorry, I will try again to ask the question. If we know what the most efficient setting and values possible are then why not set them there and not make them adjustable? Or publish them and give an explanation of how and why we should set them at what they should be at to be at the most efficient levels? Everyone can take advantage of the most efficient system!
casainho   10 GW
Post by casainho » Feb 01 2020 2:50pm
Feb 01 2020 2:41pm
There are no settings for "most efficient". The settings are mainly for adjust specifics of each ebike and user preferences, like for instance, configure which battery voltage (specific for each ebike) and motor current ramp value (user preference, like when my son had 8 years old, I did configure a low motor current ramp value since he was very small and light so could be dangerous a fast acceleration of the ebike).
amberwolf   100 GW
Post by amberwolf » Feb 01 2020 11:46pm
Powerhour wrote:
Feb 01 2020 8:44am
you can certainly measure it, but i have no idea what this firmware has for options--you'll have to look that up in the documentation. (i don't have any of these systems that any of the osfw can be used on...i just pop in various threads whenever i see questions i can answer ;) ).
ancan   1 mW
Post by ancan » Feb 03 2020 5:42am
Hi all,
I don't know if it's of any interest, but I had a look at the source and the source of uGUI and noticed that the 850C has hardware accelerated block filling. So I modified the uGUI filled circle function to use that to fill the center of the circle. I haven't got a 850C to test with so not sure if there's any real speed benefits, but if someone would be interested in spiffing up the looks of the display a bit, say with a circular speedo, please try it out.
It might be possible to gain a few cycles by calling the hardware drivers directly, bypassing uGUI's wrapper. Also since there's only completely horizontal or vertical line drawing, the UG_FillFrame might be faster than the UG_DrawLine.
Code: Select all
        void FillCircle(UG_S16 x0, UG_S16 y0, UG_S16 r, UG_COLOR c)
            UG_S16 x,y,xd,yd,e;
	    xd = 1 - (r << 1);
            yd = 0;
            e = 0;
            x = r;
            y = 0;
            while (x >= y)
                UG_DrawLine(x0 - x, y0 - y, x0 - x, y0 + y, c);
                UG_DrawLine(x0 + x, y0 - y, x0 + x, y0 + y, c);
                UG_DrawLine(x0 - y, y0 - x, x0 + y, y0 - x, c);
                UG_DrawLine(x0 - y, y0 + x, x0 + y, y0 + x, c);
                y++;
                e += yd;
                yd += 2;
                if (((e << 1) + xd) > 0)
                    x--;
                    e += xd;
                    xd += 2;
            UG_FillFrame(x0 - x, y0 - y, x0 + x, y0 + y, c);
