galp
Hi!
I recently bought this kit from aliexpress. Everything was running fine for about 200 km until today. Motor still runs fine with no load. But when I ride it and throttle up the motor makes weird noises like something is spinning inside. The speed on LCD also goes up although the actual road speed doesn't because the motor makes only little torque. Did I cook the hall sensors? I was really pushing it the last ride and the motor got quite hot. Could overheating hall sensors cause permanent damage to them? What are symptoms of weakened magnets in hub motors because of overheating?
Thanks a lot.
Thanks a lot.
