Ellectrico
1 W
- Joined
- Aug 10, 2019
- Messages
- 53
$2.5 per cell Sanyo/Panasonic NCR18650GA 3500mAh (Red) 10A 3.63V 12.70Wh GENUINE CELLS
These cells are in excellent condition, testing at 95% (or higher) of the manufacturers rated capacity.
Please take note, these cells were extracted from brand new battery packs that were installed in mobility devices but never sold so they're old stock, so they have spot weld marks and sometimes small quantities of leftover nickel from the welds on the positive and negative terminals (see pics). This does not affect the cell's performance in any way, you could spot weld or solder over them or remove very easily.
100% Authentic, GUARANTEED with moneyback.
Shipped Priority Mail, packed by a certified packing expert with same day shipping in most cases.
If you're interested in placing larger bulk orders,
I have a large stock of these cells,
feel free to contact me anytime!
Below are full specifications, fell free to ask questions that weren't covered here:
Official specifications:
Rated capacity: 3300mAh
Minimum capacity: 3350mAh
Typical capacity: 3450mAh
Nominal voltage: 3.6V
Discharge end voltage: 2.5V
Charging current (Std.): 1.675A
Charging voltage: 4.20 +/-0.03V
Charging time (Std): 4.0 hours
Continuous discharge current (Max.): 10A
Internal resistance (AC 1kHz): <38mOhm
Cycle life: 300 cycles to 70%
Weight: <49.5g
Operating temperature: Charge: +10 ~ +45°C, Discharge: -20 ~ +60°C
Storage conditions: less than 1 month: -20 ~ +50°C, less than 3 months: -20 ~ +40°C, less than 1 year: -20 ~ +20°C (80% capacity left)
Here is an in-depth data sheet about the cell and it's testing and origin.
https://lygte-info.dk/review/batteries2012/Sanyo%20NCR18650GA%203500mAh%20%28Red%29%20UK.html
I am located in the West Coast, shipping rates for USA only are the following:
Up to 170 cells = $15 Shipping within USA
From 170 to 300 = $18 Shipping Within USA
Additional products that may interest or satisfy your battery pack building needs:
48v 13s 30A BMS (comes with wire harness) -$10
Fielect 2x10 Cell holders - $1.5 a piece. (Series Mode: Two rows of 10 cells, 18650 Lithium Battery; Hole Spacing: 19mm; Hole Dia: 18.5mm, Material: ABS; Color: Black, Has room for nickel strips)
Also there is a variety of Electric Scooter and Bike Hub motors available, details on request.
Custom made battery packs are also available. Message me for a quote.
can provide more detailed descriptions or photos if needed. At this moment I have about 4000 cells available, will have more as soon as I sell this batch. Price will either drop or increase depending on demand.
All transactions through paypal only with moneyback guarantee if the quality is subpar.
Can link other threads where people already purchased and left reviews.
Weight: <49.5g
