205mm stator diameter (9C, Crystalyte 'H', MXUS etc.) V2 Hubsink
tomjasz
1 GW
Out riding, MN USA
Open package $69 shipped CONUS.
V2 HubSink Set for Optimal Cooling of Direct Drive Hub Motors with Statorade. Includes thermal grease and hardware.
V2 HubSink cooling fins for greatly increasing the cooling capabilities of 205mm stator diameter (9C, Crystalyte 'H', MXUS etc.) direct drive hub motor that contain Statorade. The 6-piece solution bolts onto the ring of existing direct drive hub motors and provides much more area moving heat from the magnet ring to ambient air, increasing the cooling effect by up to 20% over just Statorade alone.
Note The new Crysatlyte 'UFO' motors are slightly too small in diameter for the Hubsinks to fit tight. Usage with a UFO motor requires a thermal pad material to make up the difference in diameter.
