The thermistor expansion module is used when monitoring additional
battery pack temperatures is necessary. Each expansion module
can measure up to 80 temperatures and is compatible with
both the Orion BMS and the Orion Jr BMS from Ewert Energy
Systems. When used with an Orion BMS unit, up to 10 modules
can be connected together to monitor a total of 800 temperatures.
For the Orion Jr. BMS, one thermistor expansion module can be used
to monitor up to 80 temperatures.
Thermistor Expansion Module
Specification Item Min Max Units
Supply Voltage 10 16 Vdc
Supply Current (at 12V DC) 35 60 mA
Temperature Range
(Operating and Sensing) -40 80 C
Product Specifications
Operates with the Orion BMS or Orion Jr. BMS from Ewert Energy Systems (BMS
sold separately).
Can be used as a stand-alone temperature monitoring device.
Full automotive operating and sensing temperature range (-40C to 80C).
High noise immunity.
Communicates data via CANBUS or via analog outputs.
Several CANBUS baud rates supported (125 Kbps, 250 Kbps, 500 Kbps, 1000 Kbps).
Can be configured to measure between 1 and 80 thermistors.
Supports many different 10K thermistors (100K thermistor support available as special
order).
Requires a CANdapter for initial programming and data logging.
Condition: New
Price: 100 USD
Temperature Range
sold separately).
order).
Condition: New
Price: 100 USD
