EU Group Buy for MXUS 3000W Hub Motor 177€ + Shipping
Bikebrap   1 W
Re: EU Group Buy for MXUS 3000W Hub Motor 177€ + Shipping
Post by Bikebrap » Jan 08 2016 6:41am
As I can see there is possibly 10 people interested for now. 5 from September and 5 now.
Do we need more people? maybe to post on Facebook.
cwah   10 GW
10 GW
Post by cwah » Jan 08 2016 6:56am
I m interested in a 3T v2 thicker phase wire
Merlin   10 MW
Post by Merlin » Feb 07 2016 2:13pm
\/ampa wrote:Kelly also uses KTY but different type.
Just have found that i dont need swap to 10k NTC.
CAv3 works with this KTY sensor.
Untested settings are :
LinearMode
Units 0,695V
Scale 177,2 Deg/V
can anyone confirm that?
i tried a mxus v1 with cycle analyst and it shows something about 750° + .....
i wired the white cable with gnd from hall connector....?!
Nordle   100 W
Post by Nordle » Apr 05 2017 1:31pm
PM me when the next run starts pls!
4:20 Noob Hubz! BLAZE it
..sry for dat poor english..
rojitor   100 kW
Post by rojitor » May 17 2017 11:23am
njm   10 µW
10 µW
Post by njm » Jan 22 2018 4:18am
Hi, just to know if anyone interestd to form a group to buy a mxus 3000. Thank you to all njm
ltu   100 mW
Post by ltu » Jan 22 2018 2:04pm
im interest a custom axle (135mm)mounted on wheel
njm   10 µW
10 µW
Post by njm » Jan 23 2018 3:55am
Hi, i have a cube stereo 160 27/5 , iwas thinking to mount a 3000w rear hub. I'm not sure if i could use the 10 speed sprocket. And i checked the dropout, is closed, both sides. I think is not big problem, just make the some little modification whitout not to weack the frame. I tryed to estrech the dropout it gain 150mm room. I live in Italy. If we find others that have the same intention.Who knows we can afford the Good price.
burner77   100 W
Post by burner77 » Jan 23 2018 4:06am
njm wrote:
Jan 23 2018 3:55am
you probably have a X12 dropout, which has a axle to insert from the side. The MXUS axle is about 170 mm, is integrated in the motor and you would have to remove allot of material to use it. The MXUS has a 16 mm axle and has to be inserted below. It makes not much sense to use 10 speed, because the MXUS is made for 6 speed only and you have to extend the axle with washers.
Mi puoi scrivere anche in Italiano, usa PM
burner77   100 W
Post by burner77 » Jan 23 2018 4:07am
njm wrote:
Jan 22 2018 4:18am
if you need a motor, you can let me know. I have plenty of them
njm   10 µW
10 µW
Post by njm » Jan 23 2018 4:20am
Ciao. Esatamente, x12 mm asse. Per quanto riguarda il cassette, posso a me va benne an he uno a 6. Guardando alchuni siti, Fra cui Del proprio fabricante. Me sembrava que il diametro del'asse fosse 14 e non 16mm. Buona giornata.njm
njm   10 µW
10 µW
Post by njm » Jan 24 2018 3:21am
Ciao Burner, una domanda per quanto riguarda l'asse 16mm dell motore. Come viene montata al motore? Atraverso chiavetta? dalla foto sul vostro sito non sno riuscito a capire. Faccio questa domanda per sapere se serve una pressa, o se e fattibile entrare con la ruota ja montata senza l'asse e poi enfilare da un lato. Ti chiedo poi sono Tecnico meccanico, tornitore,frezzatore, A presto. Me scusi per mio Italiano. Sono Brasiliano
burner77   100 W
Post by burner77 » Jan 24 2018 3:53am
njm wrote:
Jan 24 2018 3:21am
Usually like this: https://youtu.be/R9rRpyo1Ik4?t=1m5s
The axle can't be removed. You have to cut the frame to insert it
