NEW Hailong-3 48v 17.5 Ah the big Shark pack
EMPowered   10 mW
Post by EMPowered » Jan 10 2017 3:54am
Check out the Shark pack's big brother, the Hailong-3. Now bigger and better than ever, yet still small enough to fit in more bikes than any other 17.5 Ah battery. Now comes with a power switch, a USB 2.0 port, and a more rugged mount than it's little brother the Hailong-1 aka the Shark pack. Check out EMPowered Cycles for more information and dimensions of this new bolt on ready e-bike battery. $579.99
More info here: https://www.empoweredcycles.com/collect ... nasonic-ga
amberwolf   100 GW
Re: NEW Hailong-3 48v 17.5 Ah the big Shark pack
Post by amberwolf » Jan 10 2017 2:16pm
So they're free?
Since no price was posted per the rules, we have to assume they must be the best giveaway ever. ;)
dventu   100 W
Post by dventu » Jan 10 2017 5:15pm
First dibs on the free packs.
Sent from my SM-G925I using Tapatalk
EMPowered   10 mW
Post by EMPowered » Jan 10 2017 6:00pm
oh sorry, forgot to post price
$579.99
You guys are on it, sorry, got a wife to feed, can't give away free ; ) lol
amberwolf   100 GW
Post by amberwolf » Jan 11 2017 1:53am
give away wife, keep batteries? ;)
justin_le   10 MW
Post by justin_le » Jan 11 2017 6:10am
EMPowered wrote:Check out the Shark pack's big brother, the Hailong-3. Now bigger and better than ever, yet still small enough to fit in more bikes
Just a hint, but if you are getting lithium batteries imported with the 3-pin XLR plug like this, have them wire up a 10K NTC thermistor between pins 2 (gnd) and 3 (normally not connected) of the 3-pin charge port on all these packs, just like they used to do with all the NiCad and NiMH batteries. Then if you hook up a Satiator it will automatically detect this and display the internal cell temprature on the Satiator screen, and in future versions of the Satiator firmware you'll be able to automatically limit the charging when appropriate. So that the charge rate could be automatically reduced at cold temperatures to prevent plating, and be cutoff completely at more extreme temps where charging isn't safe.
Previously competed in the Suntrip race on a back to back tandem solar powered row/cycle trike. 550 watt solar roof, dual Grin All Axle hub motors, dual Phaserunner controllers, 12 LiGo batteries, and a whole wack of gear.
Now back in Vancouver learning to be a dad with my Big Dummy Frame (yes This One, thanks ES!) with GMAC 10T rear hub motor, Phaserunner controller, and 52V 19Ah EM3EV pack
My website: http://www.ebikes.ca
Please contact via email, info@ebikes.ca, rather than PMs, which are disabled
EMPowered   10 mW
Post by EMPowered » Jan 12 2017 2:03am
Amberwolf- thanks for all your volunteer moderating of this forum!
Justin- thank you for pointing out the compatibility of the XLR plug with the Satiator and for the info about the 10K NTC Thermister between pins 2 and 3. My packs are wired the same so this can easily be done before shipping out. If anyone is interested in that option please let me know. I don't have any of these resistors available as of now, but will source some. The temp sensing feature available in future versions of firmware is a cool feature, thanks for always coming up with new improvements and being such an innovator!
larghio   1 mW
Post by larghio » Jan 30 2017 4:49pm
Is it possible to connect my old hailong battery case to the new base or visa versa?
Sent from my Nexus 6 using Tapatalk
The commuter: DBS intruder f7, 8t mac 24ah 29e pack from cellman, bms 900 charger, CAv3 PAS&throttle
GF bike: Merida, 12t mac 12s1p turnigy 5ah, CAv3 PAS&throttle
Raptor: Raptor 140, MaxE, CromotorV2, turnigy harpacks 20s5p 25ah, 30a charge coil.
999zip999   100 GW
Post by 999zip999 » Jan 31 2017 11:04am
What cells are you using ?
EMPowered   10 mW
Post by EMPowered » Feb 03 2017 4:41am
The Hailong-3 uses a different mount and cannot swap with the hailong-1 mount.
The packs have Panasonic GA cells.
