Bladez XTR SE Build
Gabcauseican
Currently have a Razor E300(48v 1000w Lithium) project going on but my brother made an offer on 2 Bladez XTRSE for the low.......$50 later had a Bladez XtrSE
2NFbqRK_1XthOgJBzeg1jiXB-Gm6-AyQmuYHHXIt5QoNXjcefA0Gjb8jR6UPe9d-uNDXbvtB7Zar5ckRLkJKLhuav3qgYjJS6S6OmRe858Fem6SZwgklq8C7dGYoICu8liFy_f-0xH8=w1920-h1080
CdMqVl0OYkAYG0vg5AhWQyblf66OqfBa3itrN-bOXhv5W5qAZVLJUzKYxrE0iKw2gBbyQYBMxva9fgUF3KHkL2XLKlwkeDvA_UmguXETGMgNG_YW8y4UG5pdDMx7rRl9ofCZdmM9qeo=w1920-h1080
His offer......I just picked them up.......
They both didnt work.....hence the cheap price...... both of them .....throttle shot......had to find the sweet spot to get it moving.....wasnt what I was use too......but it was 15mph felt great.......just wanted more.....the frame felt better over the Razor to me......
Fpd-eK1jdzODVV6rRcDsckZIyQ6L-uI5mzP0i6LhFZ53oo_MkAzI_piSHm1qmwD9PJCa5c44v6RgjePr8-PsT2F_DLqO9SXGwrl4xs0EKCUMlVE9UNOdDbWaL63-Z3C7hvJYVIODkPQ=w1920-h1080
Looked around from the left over fail project pile......... 36v controller......
_z8I9_aTtXsBuo_NpdpXUSuhObt8MqDqNPnJkQPVZsFqURluZ-7vhn6RhJTH7IvOhMaUb51ee30R_v8tU5Di1TUm8UOAzlvgamcyPIGWEXZFS16LZUECF12L9idWSp-SvCrBEWFA5kQ=w1920-h1080
Seem like it should fit.......... :D :D :D
dZWBgsfBwOpQa8st3EZJ_hhBF08trSA5Re4Ifsp6YCsa2aLhM6WxVL1qJKbrsVNkUNXeNZVtNKXEiSSHMRcC--QII1-Tcxl9AWeCbrgDNHtftftFdkIlrn6D7J6uCXNSTJKwmOr82ng=w1920-h1080
Used a DC to DC step up converter.......on load 38.5v no blowing up just yet...(14.5v overvolt)
o37LXmmDxPSMezr9Ja04fIJq2KcBEa_uFxMC3ZfLyirJI4cc22YLAkVPoliNwz4xu5TTv4nfZC_T-fRxjvwJ0Rq2HU9fgDBXeITGBqjjmx9Ju_9mGHasPv-Tosmqut6mhbeUtomh2ME=w1920-h1080
Wasnt bad.......wasnt bad at all....... it's the way the scooter should of come...... the way the motor whine :lol: :lol: :lol: :lol: :lol: .......you know its overvolted......the motor act normal....... but when you full throttle.......the top end pull tho...... took out the DC step up......only the SLA 3x 12v 15ah( 41.4v) my brother did the speed run for me....... (still didnt feel fast to me :( )
XZiQyKD25eem5Onv0D-us8-7J1Co8UXNT99CdzixFx4kICgzGd3ehI6pMxOF1OZ0do67Nj8N9rNQ47KcEofY6_V5zWPrabu9zodZN0dM5IamruHxUISG7hPJgroMBpTXGtrH2ihjKoU=w1920-h1080
So I striped the Bladez and wanted to tear down the razor...... but it was too much wiring to undo....... guess I gotta look for a new setup
7e6F0OzW-sEFhqh_4Pn0ecjWF1IvKaMJizfiugjOAzuy9-EEgFIKt21vrkm0u6YXCzX80eeabYUhUVwNGWGCTZgRYUTPjpAHf1_kxI6qaxHG73fpq0QP0nh6yBI8eU6n3OJglB_apno=w1920-h1080
xmRbfXwRZTEhZ3SkOATo3L5rOXFuwHO8zzWxSfHMAJLDDtibPOgPXJmgv7gCEAP9CokRb2_wEQDZ-vbGxM1bAYxk7rQRccYo18Vlw1he7pzFjnkbniqJq4lbnG1eoP_2RKeNaB2hix8=w1920-h1080
Started the build process......... This should be fun........ First thing to go was the old variable throttle and replaced with a new 1 with a key and voltmeter built in...... kept the stock brake...... just spliced in the brake motor kill switch.....
-v0rnRe-CILN5oyiwCF1jtDC6TTbMMa1PUiKWBpT9SSha0jNSYG4REwFxsxShK0Fk7MziSeen07r7RYngUafdtE74LkhIaLqOAB6UFFpHF654rOfZHWEAWmV2_MVYJ3_WE0XpNM_gd0=w1920-h1080
Now how to mount this brushless 48v 1800w motor to this emptiness
SstiOShOwWpF3t34Scr6p8bf62hxGp0K5KQ75vV89EeLthRKXwMVPJKVSvNc8rkE5KDmfcjgSB1rd9bnzfjFisUnDbvOsxeOFv4fNnVPMtc3T7tZvI8xwXpFHbyYi4xa-svlH1mLC3c=w1920-h1080
mePiVyL8LjK3-HZ43dw06AhWI1QFMQprG7IMlEW5vE59aGBJjAOit5Sg-1JrIUVc-OzfhckVSR-eLtOFSidOk2MWeh-fZaTbuQglnBkGJfZKesvpbJ4Sz2tA20GjLhF0VMzeHwNxmdI=w1920-h1080
After much thinking and planning.......The masterpiece... :D
0ypmnXSHxZQ6SQkldHw4tsWm-fIrff2tjp-hVTOjivE87lK5ty0P0lLLRpBr_M0Y3i7sHLW9CHPH-a60i6Nzr4DNHgLXr-uY3i7IiiTTAyZcx0-GsUIK1MLqW_udRD3QdN3-KXoo7Cc=w1920-h1080
0fMqhWpQX20YFt9rciU6A-zVZxhTQVJBhDHJixOudqqzybpe2ofO9D0ug3_7Tm5L0D6HfsuOSdhDZ1ZUN9tgyDoRzE68NIEM5fZv3CE9bTHU0RnOl5zdAhNVBWUYqKFQOBtf1jPgCi4=w1920-h1080
Yes the motor fit pretty much straight......have to drill my own holes.....but it should work :D :D :D :D (hard to keep the motor straight and take a photo.....HEAVY)
qjd25YpGgJILAJev80c49vdZXnh-KnHWmA0q5Zax_IY1Ed25vi9NhljUUkDurPQgyUBAxght9H0ETiGR51VLTnE3dbcMX-rH4iYyVHtY-AZoFBHwBN7iXCDVO20l0aXScC2qk2-w98E=w1920-h1080
Problem......the motor has a t8f sprocket........wheel sprocket #25........ I don't know the bolt pattern of the sprocket.......
58_TL3xO7kpk5irNwsQh_olxtdXkAk7nkMFsJgxil8Lru7z4kxL27JN8aLymPY_jYVTlz3gb5Wsu_xwnOBzm8t1Uh1QDEJapdkUpyWx8F36XPw8lXyfueCu8Y5bLB0cOYeB6kq6nTgw=w1920-h1080
Solution....... E300 rear wheel...... after banging, heating and streching the frame........adjusting and swapping spacers between the bladez rear wheel hardware and the E300 hardware....... have a creation.....
BtM0-ZoZx5TyriH_YxHO7mzkK8dgExabU2PUvJ2QzEsfaFOGZc8hYqM6e0_XDS6bLg3rK7N6P-h69HErnvQPbdIzSfGQq95lLWlU1maiI4jF4G8naLCwEsOSoHOMCwKdsEFJ-AnwVGQ=w1920-h1080
Looks good...... not perfect but proof of concept.......makes me want to continue.......
DMVsE2D1XYammbAHP5ZPZSipRUBr_AoADZIV83CTR_t0gtDMEsv2aFYquyqzrszGZ3d-lafbSR-zuFWCKhr2QL6UqdMtNVkxInKOJzX9itQPNGBV4tt4Fjwmx_epbv0yVNI_g9ZJ6lQ=w1920-h1080
The motor offset look crazy......kinda like it not sure yet....... remind me of my go-ped when I was 16yr...........
yRANIb112ktx_KSTxXDvGPwspFhfOykUHEFVDXJlLf8vFmFGZqcdDnbAKcYJFJDHn9jKqvRA9XM-pJ7JbbApNEap79DHYfNevQzrRQQoguI8W6gYLeJXswrwTa1CmMueoyfOePgF7Q0=w1920-h1080
Finally got the chain mounted........ broke the chain breaker tool.......2 min job....... turnt into a 45min job......... wish I was running a chain tensioner......... just a fan of 1........ still need to grind down the frame some...... chain rubs a little when spinning by hand...... not enough for me to fix right now....... put the seat on just to see how it looks
gKN3dXdoh3MIPe2DPBKmE8NksHzqa32ULc5u4d8TCHtR8VwqR_g6cFDIfkcdKlNMjypZTD9c49u7CiAVt0rU3HVos9lD9QdOtO9a2q-zdqEo_zssHtdckU8l7PKRQiClLZlZTCBdpRo=w1920-h1080
Removed the stock on and off switch and XLR charger port from the stock location..... added my charger port....... and 3 speed low/med/high switch........
0mi_QNBb8A9peuHeXAcQo56Hh_bqogheV-S3KsyON1s2EqvVYfsXdCfS3-VbzhZrIDM05k1XgDWLsfqEEkvfiu2HCKrzrXDCbpktIMG0w_0rsiVBwAIKWUm48GfWPTMhiioxmbfQ_rs=w1920-h1080
Threw the rear fender on just to see if it fit........yup like a glove
dYFvCFgZIbbXDe3CorURci3U0vnJrRBFh9EcOso6KT9Hqf8pQrwBZ373bVz_NvZwWyJIz6m8UsJx3H6DFCsO2OAA-xPoZtT136kKW8KkDlo797ehoEzup1FIl34vkeyygom8PI478kA=w1920-h1080
All I can say is wow....... going from a 1000w brushed motor to an 1800w brushless......its night and day :shock:...... no matter how hard I try to keep it down...... yup..... it tends to lift up..... but if you can MAN up...... and hold it all the way through...... within 3 and 1/2 cars.... I'm at 28mph.......
zUXwUu2UdZ1PHUBUQIrYbxf9OsYTKwYscN_rvnp6pyDnIh9JKYE7keA95zd67lQRLcEFWy_8qfH7SmVQMgkKs9rvyO5fiGJ4Xkg3KJ-Ermt6rM9mScYfd7NaGsoo81cks-kmiccEiqU=w1920-h1080
it's not for kids....... the torque...... the torque...... I knew it wasn't in my head..... the average speed for 2mins....... 20mph...... but it seem like I was limited...... the scooter hesitated......went.....hesitated and then went........... maybe the battery cant handle the load? Idk......... so I went looking to see what the controller amps are?
l6wldCpKauuy_5Trdcua6uxxngVd9rel0bpNbit1UFClYPm6sCVMYqBCUqbdMmwN2c8z7fMyaZSKdIi4XAklIeio9wCK-kbc5PsKBSKN-T2YYN3A-Y1TflgZlzdQ8cM-QDRsPWqFOAI=w1920-h1080
Quite didn't add up in my head? 48vX33AMPS ummmmm I think not....... but my battery off the charger ...... 54.4........ 54X33AMPS....... more like it but I need 1800w @48v
Went straight to the shunts...........
M6E8CQZj_n9kNVzp-RSCqNIfcTWFp6DUPZKhUPyNn2wBtElpRPT2VZe3Oh5ZlcCdykTreTD4Slc4p0F6AjTi6sRgzyiBMqmqHB1vBm0kXKcV4ExezTvKBqQJ_p935A0lJn6vv23XlJk=w1920-h1080
3 shunts? Not bad not bad...... I really hate modifing shunts...... you cant control it.......it will send whatever new current you are creating instant........smooth start......goodbye...... until my new controller come it will be my test unit........
_kDTl3zjO7Jqa_7krg1bq3Q0gFGYXCh0xryYm10ong5pqLyLIKg8-fOivYHJNTYJrmxgYP-_4FGqzwLVWkQZJk5ZQfxrRWKTKIAchGr5jTpe4GueBnkEnxDGM9U0e3gRAq-pU4R3GzI=w1920-h1080
Now is it worth the mods.....NO!!!!! not at all...... 4 of my friends......yup ate pavement..... (kinda scared of it) but I know its more left....... but for 51seconds ........ 19mph average but 31mph in 51 seconds...... unless you ride this (DEATH TRAP) you wont understand...... you cant plant the power......(its FAST.....and TORQUEY) I dont want to go faster.......
So my brother called me to Brooklyn....... we rode to Prospect Park.......First time I had it out with someone who can maintain speed and tried to cruise with it........I cant hold anything less than 20mph......anything under 20mph...... the front tends to throw you off if you apply full throttle...... but oh boy is it fun...... it more than enough to keep up with traffic.....25mph..... but like I said..... she had more she did........ new top speed 33mph......
KoOHItLKA0C1k1i2x19OFMg99CHNbwT0B7Od5jFDT6E9WPW63A8HM4iKSwq7mFxr1aHDKd3AIYwoGPQIQYX0qBworZ4qLyDZ5dUhquP8j-XNeAujpm-6NUV6bcIJ3bjiFGzXvG8sCvw=w1920-h1080
Now I'm limited by the gearing......now I must change my gearing....... have 2 options...... 39mph and 45mph...... but what I learnt from my last build........ faster you go...... you will lose the ability to climb hills...... 45mph is great but not if it takes me 10 cars to get there......takes 2 and 1/2 cars to hit 33mph.......(live in NYC...... CARS dont respect bicycles.....let alone an Escooter)
Nice upgrades. Now time to get a more powerful controller. Make sure your battery can handle that though.
That being said, it's a real pain to read with all that punctuation. I bet your keyboard "." key must be pretty worn out.
Now I'm having battery issues......... my battery cutting out since the shunt mods....... my bms 50amp (100 amp burst)....(back to Math :D :D :D :D .....48vx50amp 48v100amps) coming off the charger with 54.4(54.4x50amps 54.4x 100amps math over)..... on load full speed 33mph.....44v....... (not including the hesitation...and skipping) maybe to much on the shunts 12 gauge stranded...... I know I'm killing my battey.......
After some rough math..... know wonder its trying to kill me.... so I order another 48v 20ah...... 48v 40ah= 100amp 200 burst.......
When the battery came......went straight to wiring...
9HCZADy_oHzfsArqPkkRvRmmHN5lr9jgowk3qE16Fe9KmRJnBkzEAZ6RSEH-8vdMcGzYU4OOEXCvrf5dZ-Pou18icaGgIb93bLjV9orG0uB9prj3SA-fsved0dKQRXeG3E3cMDEon6w=w1920-h1080
Speaker wire......XT60 connectors........now we establish..... I measure 1x cut 10x....... where am I going to put this battery
LlwbXFIU-qmGB_2zvs4NryPsXhUWctfUt1Z4Wkl4GRtTJhmKe8Ii0A5aCxtwWkviwWLZYVSCuNdCUO2ZJ8FqA3JKVyo-rewUX9YhVboelVACLZhXfjNZhjbCY3ijp52DzTyDiQ4a-Lw=w1920-h1080
Inside the deck
icdq2L8uzixxvnCTda8EqbegWKzFv2XEG86p_ZjcmMAyYzsMYLVEYt3CDuoNpHv04XyGlIYXCI5qo5GHdHmramxbQ327Zg2wbT5zzlcMO3us69N64cH-1TXA42EGhCij8ST-vfd7LYo=w1920-h1080
Yup no room...... not wanting to modify.....cut weld.....ziptie or duct tape...... kept it simple........
Ld7y-hD1kowaVTDgFWZdcUSEHSpYBxaGJD5UWKBoTsCRnKqHbTULzWkX4nRSUV-1Xmw05U1Tja66PEYU2Ub22IJC_B-6dbdn5vED9-MnOAZnUCmXyJr4-pvGzvjjkXWX4isXk0zb7No=w1920-h1080
8mPxVsZREHxhkNKsK4Eq14gX8Ie-rCcdImwvZ-iYrPzlPkLWmpzMmuj3Vff4FVhEbGoDfarl5eF4vApuwfNcD9dOpkSNf7hqooBdpmDuprIUDZASSnFbKj6uFybWGfa7htUuCtH8nCs=w1920-h1080
Yup battery backpack........ (Keyboard ? Lol people still tied to a computer...... all this done from my phone...... auto prediction text......we living in the future..... put your keyboards down.....cut the cord)
So maybe it's me or maybe its me......(lol its me) but I think I blew the controller for the 1800w........ the throttle is dead.... not the throttle but......when I turn the key..... its power....... twist the throttle.......nothing.......
pC8ZfJYZbYGfGo5fl5dNeVq0k3VeM3yfPkWHcOCGceC4WuD8IsNBoJRRBnJttAa3RFMi8mR8jD7KKoeZEgkSL0-0pTZV5sjAlWNEYOC1bdR4ourSuHyrnT9U53I397b3oYR52pdJl9M=w1920-h1080
pulled out the multimeter...... the controller side of the throttle
hrm6lxa-bRiwEzIygMGGv72vZBiddQVeoxAU5svGSrMwFMiqc9UezvaxXhYmshEJR5KBJWN3cbBtH5C8a4nXGy04N78bn6MUg-GJCt3tWxLPAiXxCmz9HeU2wbgXotVxX9fuhQ9POSs=w1920-h1080
The signal wire when not twisting the throttle
-08eXPfnf8B6wf2qk5Dmd9l6t0vM0VHAHmC5RwEYcSBYA8Bmb-vSMc_1jQ4rOhwKCykfZ0x73yUPuF5odNNnQlK3GGiIKd0Re-omUADhMSM63VmtAq9VmHOGbwzqoAfTszt0JfcIhtA=w1920-h1080
The signal wire when twisting the throttle
tbsC5M9LkyHLUNnIdUPlpy2gmVafLVYBBo5IcL4qiVma2RdsLnCVKM8mC3-07nJ1MS3pLVWu8PmS4CtFQ32M6YOEJyFRrebFY49EyvyMcZoNsbDwviAhaP1VUucYLfEiB_9ZVgsLcVk=w1920-h1080
Not wanting to waste more time and tear apart the controller.......(tested the mosfets good) yup.....still don't move..........
Determined to keep riding......... swapped it over to the old 1000w set up that was on my razor.........
XJkWjsJkfVmd1nIqZ6JU3GI-WBCz_MGTslPVmro21tizb2PHdYhGFKhutpWzTEorQ781cEb6wWOk4VIrt_lI3-hVdMYjWV4cjrWFLqkBymAkpicbzbCiRJtIJkZjnSuoih5sQM34DWU=w1920-h1080
This was the fastest scooter motor I owned at the time..... but it's so slow compared to the 1800w...... I cant believe how slow it was........yup next move was shunt mods.........
The down low torque was enough....... didn't lift and try to kill me.....but it did lift enough to make me earn some of its respect.........
fNKYeHymOneRD4laZaCa8lN6NRpgN9N4c4OMPS90w49W17VY5Lg0QLI00T1MT3F6kcsG2Sns3kOpWpSThGlFN5iu-OY_Sy4qkkISr-okOPrgP0RD4rtBXwSaVTdTtJV-r0WTXOVWA14=w1920-h1080
(Notice how DARK and BURNT the SILVER faceplate is?)
So now I'm 2 weeks in..... not 1 issue.......everything going good........ it's no 1800w(controller in the mail) but its good..... I decided to go to Brooklyn from Queens......(this motor did it once already.....not shunted :lol: ) hoping for the same results....... 3 block away from my destination........ I start to lose power....... I slowly turn the throttle......I hear the chain moving.......I hear its not moving as fast as I got the throttle turnt........ I just knew the FREEWHEEL tapped out.....happened to look down....... FLAMES..... no blue....only orange FLAMES coming from the inside of my motor........ I PANICKED, jumped off the scooter.....started blowing the FIRE out....... it went out...... but now I'm in front of a restuarant with outdoor seating(the smell and smoke coming out of my motor) people was staring.......EMBARRASSED......took that walk of shame.......
The aftermath.....
lKBU1lltBqPIrUb_VwdC7_DBwTf_1uX3IPM1wPUFwO9AZfiruN09iN6Yajb7CSO6C7Z1nxnzeyrefdlMsXcnI2AYK-T7EL7QawfsLHXxkb6IeoB9CowAQaAhGjRl6OABJ61bJ0wt5LY=w1920-h1080
The wire shielding......melted
HLmEAFqt7n5YtR9q66A8K-adxJ-KRvzUU1OyHixkS9GNFI-mK6Ol6zyrr86z0EA12ksHapNfp-nWUeC22DM0ine__8TH_og7LZM6Do3wdyLIKVKRWTNojBHNdtgQietYennhWFXsVmQ=w1920-h1080
Xt60 wire shielding melted.......
IYN5ZVI_n8YNn6hokEZOgiq43s_cWvSMcOswSAPpzRtoIaNUy42nw3iKF0JmvbLXO124yOlcDIdyTIugM7pX2RyZbOjnrG_KyAXUYOnT4l-Tq-1KZymaDTFPmvcHhzzGZCBhgx9oLHU=w1920-h1080
Speed controller POWER and MOTOR wires melted together
CM7LPRexT-Wfx2E3XwFUWgQ4XNpFvwktPj47BSIgP2fjwe0l5ckBqoCX6ZknHh_4770PlQyDhQScJLsE_TGw3FT_10kyDf-R-2HgSVwgGs0ad9Mo32vM1hMWHwinFOUY_qbHKrgXlEE=w1920-h1080
The glob of SOLDER that started all of this......
What I learnt so far......... invest in a good BMS.......short circuit protection cutoff saved my life......over 180 lithium cells was on board.........LOLOL nah for real...... leave it stock.......
Now after 3 days of no riding.......I couldnt wait until USPS pulled up......so I started the motor swap.....
iHUZBugEvqP1B4JYOiBoAse5CW1y2bffy2MqwovKQX5VswajG6SJJDm5b7Aj0mCsOKy-W_zX-9Hubgqnwm5GI1Kfo4LKEuCCV0h0HnCmPl-X_WJNjap6dGtG7XjFN_ujrY2zQNi2NCs=w1920-h1080
Maybe 2x motors set up?....
Bu6lyVVV8t4nnLFoiwRozVl6fg6ltTqx-sPikOovd9RWL9B6uK6-ofAN5OvZuVOjlj1lVlG_ckkoufRENV747sxm6FYk18P33y4zmE_wV6sW3UK9u4O47nhSHugqzGZiKL3VyjcGRcE=w1920-h1080
Now on to the wiring........
08rzp32u6jlJaPul8zhaOqZmd0xJhwIOLmIlf77eoPGOfDJh_eR_0caIYF3l8cQ80_kMagtNmLvv6_UZedMayrLVDSjUsmvcKdv55k1Te8btm9MDkX4dRLBg_pEMnK2i0AP_GhjOggo=w1920-h1080
My brother words in my head......why you always taking apart perfectly good stuff........ people take apart BROKEN stuff.........
2la3gNH9ipHY68_7V6GJK40lJDv3vDvIOjQnoEQJLvg076vJdBKwIujcUFWBGjsWI-W8yjgkV5oKiCLkGzKdbpQHfBcyHywf1GmqEDOKlkwrfaVm52axDgwUKg2ryiMoaquVjt1bpIM=w1920-h1080
Yup I had to see peek inside......not bad easy to modify.......
8mDioLeAB0i79bD8YYsfAwh2hulLHcELZ2-2wt_XjFRfeJmN3769MUnaeyTP1K2qbJrCo2LkiB6Aj2beWdzXxGkZkOywsbp15itWELCO_aVEToBOSgya_wyFRahNdsYQNbEC6H1ml3s=w1920-h1080
A little bit of solder on the shunts.......nothing to crazy to burn stuff up.......They say people talk from EXPERIENCE not THEORY...... :lol: :lol:.....everything went well......but couldnt get a speed run in.....had to help a friend get his 36v up and running
6jTcI1s9xdRaTHSFCGZGuTPEVLl4KPSd3FO4_DnGUmkxp6ijNPgtl2rwScEIfnmkqJa3Jl7MWwaS54hnzvfs0vlGwLpS4X0rj8m2ptZVRc7Q6pcwYBNb3dkBYdQkaEzLZtG5yadLl6E=w1920-h1080
3x XT60 to an EC5......took way longer than I would like to admit but here
cJ_d4yWVwVN32ZEld4xTMHMd0Q71_IGYalvLmXX-b6-UCl7M9IqP2y2tMYzC--og2E3O7qjwll5Iu1bOKP6Kj1M9JbNAEPhbtHXhZGN6pd5qP1aN39f3cDsAHITDYDerUUJ4_BpkxPw=w1920-h1080
jHXCrso-Eln6auOwnCY3wJk6jdWQsz1g7IAymzCit63T0CFptNgaBaQY2ieogSwarNCzonpK2M_HxsvWxowgCh8bJnYbeV6CBS5_MSqw--koZT5yNbPqI81mnhaxN47QE39AOZDwUt0=w1920-h1080
The next day.... trip to BK(6.4m).....why I would go.....I just burnt a motor going to the same place but.......it made it....... no real pulls....refuse to do the same thing 2x........new top speed was achieved in the process
q_591Zc0qX0wlE0u_pRbw6ZXjOZOzdbo0TdRV9lkY3Y_6nMhydAJMcj0KzSKJLR-OhrZOD79PmVqzV21fDmZFN_maN2hyfcjYtmmkBOnrQuO-jpcShJGUFNBN-7lH8shSKHgdQXuj88=w1920-h1080
Just when I thought I was done nope........ friend couldnt get the E300 (36v) running......so I gave him a hand.....cut into my time but riding solo is fun up until.......
KwZ8Kl2Oe3hFeKfjxh_7-QumHAbgPZ92R12Ce4-qPnlkw7QW90MuWCorvRDPgY9y-y4XLl4YCAPJCf6-v4FUNK9Ur6bJsjpBAQ2P2TvbzqLTNr_2EOzb_aw0zNkPtfPcE4sP9tIAHn8=w1920-h1080
It was only the key switch OPEN......jumped the 2 wires...... and we had a running motor.......he left his charger.......you guessed it me either.... if you got lemons.....lemonade it is..... oh it took forever to charge
U_3v0-8qKE5Ij5aMRci75VE-woXdV4yeSSTxD6oBTIDL-dpWBkKjiNwgAakLkdYCQzEbXjppxEZi_5dFzN0kawcQ6dduIjgdQbwiGtx47_LpS6lu1NkbOJcxA2EezHXMp2ZBwREV2xo=w1920-h1080
After his scooter was fully charged......... we headed out......I went for another speedrun......wasnt too bad but new top speed was achieved again.....but the 36v smelt like the 1000w......I told him chill cut it off you cooking it........that was it for the night/morning
4hbXIKvMa5WgxC_XxPOd8CIKGZkVdvF9GgOHdIKx858tw6zqUoTS3QHaIgi-UBLDE7dWXcCAYtgLGgYV-iJXEtthNeGHyaf-jAukb2NDGCH0P2dLMcTJszo-C9FjhCFuuwZZ0lDa6cU=w1920-h1080
Got back to the house......once you know a burnt DC motor smell like.....it made me rip apart the 1000w to so the damage.......
DvkWxFglmU_OufSxjBvaX6ILNoOBlJnPy4DnA2Ym43XsxJRW0UFimIzALaOiySBDv6Ko9Qu1wBriun-NY4o-Jt1hnzV4sjU_qZ4g0kA1Xnn1fJDzaoZuC0ZTzRjU9J4pqa1TnMcoNoI=w1920-h1080
SAKOfqCsv9Q6nh6v3PkLQWByP4kBU628Z5UcI61sXABwKoRYLrkDyKiSECd4ydgBKgsSv-NXO6dMoa7oBgq2P81sqngJrBesptSIhrn7Nd6Q5KZkXqQg_p_p-WfP0TI6gxTSFYjiT6c=w1920-h1080
No matter how hard I try to break 40 mph, I just cant..... only topping out at 38 mph...... granted its way faster than a scooter should ever go ....... but my calculations say 45 mph........ every other calculation (Calc. 27 mph I did 28 mph Calc. 33 mph I did 33 mph) Now this is my disconnect......i cant break 40 mph.......This 13s 40ah isnt cutting it......... time to up the voltage,shunt mod only isnt enough for what I need
JZFka8Hm7OZ-c2NJrIz4Bj4kNvaSdbmLssrpg93nPaMhdedEthQ7YEwo57PbdgTNpUIkhtFdl0WlbTiSvUjnBH4wxGFEY5w-Nb6KnTWsgJUbT_lBt3fUiRk96Df6D4Lp8PsBqq40SAE=w1920-h1080
Unfortunately this chapter has come to an abrupt end......Its was all fun and games....... I thought it was funny...... until my friend slammed into a park car at 40 mph.......yup the scooter totaled(preview of the new build below)
u_FLLFjPzGt8dhrHfI4wd9UBNEouuFZIraXtdwZn1AfzjC0z9PNulCZsmwduMCIzCo29QWcbzXIsheiGvmH9tXVZbb7DSPtcTClbl1ykYVVi3Zap4hfnv1QwStmRJDgpJ0S4EHvhnVc=w1920-h1080
