Vesc Motor temp cut out
dmcke5
10 µW
Hi guys, having a bit of a problem on a new build with a Flipsky VESC 4.12. It's a single motor build on a razor e300 frame. I couldn't get the latest version of the firmware to work on this vesc as it throws an error about over current and won't let me run the motor (this seems to be a common issue so it's not just me) so I'm trying older firmwares. So far I've tried 3.30 and 3.38 I think. I've got the motor running nicely but I'm getting a motor temp cut off error at about 60 degrees. My cut off temp settings are default at 80/100 but it doesn't seem to be paying any attention to that setting. Any advice on how to fix the problem?
Cheers!
Just in case anyone else has this issue, I found the 0.95 version of the vesc tool which is fw 3.40 for the vesc as it has fixed the problem.
