Hello.I was wondering if someone can help me with my problem? Does anyone knows P and C settings for Kunteng controller KT36/48 SVPRM 500W with Kunteng lcd 8HU and 250W LIME S3 generation electric scooter hub motor? It has 30 magnets. 10" wheel size. When i pull the throttle i get HALL SENSOR FAULT error message. Motor has 5V and 0 Volts on wheel spin check,so it is not the hall sensor. I guess is LCD settings? Everything is connected as it should be..I have tried with my second hub motor 350w and i get the error message again. Can someone post at least some main crucial settings and i will do the rest? Thank you in advance for your help.Best regards!
