Mercane WideWheel dual motor 2019 rebuild
Sinhu   100 mW
Post by Sinhu » Dec 14 2021 11:23pm
Hi !
I found a beat’n up ww i paid €50 for and decided to make it the project this winter.
Starting with taken the scooter completly apart, and the list of parts needed became long :(
New main controller
Left side rear rim
1 new tire
Headset bearings
Plastic wheelside cover
Break disc
Down part of dusplay housing
Starting with the suspension, remove the «hot glue» used from the fabric and clean everything. Paint the «fork arms» and using a shore 60 filler covering det springs and joint too the torque arm.
All the «squieeking» noises are gone and it feels softer.
Paint and filler
Filler
Then it’s the sad sad breaks this scooter comes with, switched too Magura MT2
Magura mt2
To make room for the Magura calipre the break disc needed a 2mm spacer
2 mm spacer
Magura mt2
The breaks now works as breaks should :) realy sharp and a plesure to use.
The next issue, lights:
New frontlight as the original lights are not so good. A cheap led light 12-80v from aliexpress ($20) and an solid state rely so i can run it without any extra switch.
Led light 12-80v and a SSR
And deilled a hole to fit a fuse as it runs full battery power.
Fuse
As i replaced the trottle with voltmeter with a Wuxing 108x trottle, i wanted to be able to see the batt voltage and have a key for on/off
Installed a 2020 pro keyboks and a volmeter
2020pro key boks and voltmeter
Then it’s the heart of this scooter, it needs a new battery pack. With a max hight at 70mm and 530 mm lengt in total that must fit 110mm wide
Planing the new battery pack
Will build a 14s 52v pack to ad a bit more power, and with LG M36 cells it have 21Ah maybe 24,5ah.
Waiting for the Daly 30A bms to arrive.
Finished WW with new sandpaper
Finished WW
HTTR   10 mW
Re: Mercane WideWheel dual motor 2019 rebuild
Post by HTTR » Jan 08 2022 3:17pm
A lot of work there for a widewheel but guess that this one was about the journey ... an ya did an amazing work by the looks of it. Congrats and don't forget to show some shots of her finished and also curious about how it rides compared to a stock one.
Sinhu   100 mW
Post by Sinhu » Jan 22 2022 7:40pm
It’s tru thats a bit of work, if you don’t have some parts laying around it would be a bit expensive to.
But one thing is serten, switching to hydraulic breaks and do the suspension makes all the difference too this cool little scooter :)
