Skippo
Hi this is my 1st build post so I am starting with something easy.
I got a razor ecosmart metro a while back. And it came with an extra controller, throttle( wire was cut but repaired) and even a brand new charge port and brake cable, so I borrow the idea from another post " accidentally double scooter build ".
I got a e200 and make that 36v.
Found one with dead battery but everything works for $20.
Got 3x 12v 5ah SLA battery for $33 on Amazon.
Added a 36v 40a relay so I can use a keyed on/off switch. And fuse holder with 30a fuse
Added front brake calipers ( have to modify to fit) and aluminum front wheel ( stock have a plastic wheel) from a e100. The brake lever do no work.
And switch out the charge port so my 36v charger work on both.
