Daveograph
- Joined
- Aug 6, 2016
- Messages
- 4
Trying to connect the following systems on a single DIY escooter
system 1
- battery 20s8p Sanyo GA 18650
- common port 300amp discharge, 50amp charge bms
- Controller fardriver nd72360
- Motor LY 11 inch 3000w hub motor
system 2
- battery 20s8p LG mj1 18650
- bms duplicate of above
- Controller duplicate of above
- Motor duplicate of above
X1 Throttle, 3 wire thumb throttle (hall effect sensor)
Instinct is to common ground the batteries and wire throttle (red, black and green) to system 1 and parallel only (green) to system 2.
Would this work? or would the 72v packs attempt to balance through signal wire?
system 1
system 2
