Jedimack23
- Joined
- Jun 19, 2022
- Messages
- 2
Hello, I have a bird 3 scooter and I'm converting it to personal use. I have a brainpower 48v 500w controller in using and I've wired everything up the way I'm supposed to based on other videos I've seen and researching and learning via these forums and YouTube. However my throttle has 4 wires, it has red and black which I know is 4.3v and gnd and the yellow and blue are supposed to be my signal wires so I've been told to hook up the yellow to my white signal wire and that's it. I've tried this and I get nothing. If I hook it up to the blue wire with my white signal wire from the controller it works the opposite as it should. It runs immediately upon getting power and then if I push the throttle it shuts down. Obviously I need it to not run with no throttle and then run when I give it throttle. I also want to mention that I am able to learn it to the proper direction wth the green learning wires. Thanks in advance for all your help. I am a noob so please be patient and kind! Again thanks so much!
